Builds 2F + (3F-E) = 2FETI Into My FJ40 (2 Viewers)
matt.mcinnes
2F-ETI
Melbourne
2F + 3FE = 2F-ETI Into My FJ40
Well after reading a few threads on grafting a 3FE head on to a 2F block we have decided to go the whole 9 yards and return the punt for a touch down and build an injected turbo water inter cooled 2F.
I already have a worked 2F that rocks that's been rebuilt and balanced, tomorrow I pick up a 3F-E complete for $200us that was pulled out and replaced by a 350 in an 80 series . It was running when removed too.
My 2F, the last dyno run. So we know where we started.
BLUE PROPANE
RED PETROL
First up will be to remove the 3F-E head and have it worked, ported and polished plus what ever else it need to suit the turbo.
So for those interested watch this space for a detailed write up.
TEC SPECS COVERED SO FAR IN THIS THREAD. I will up date this as the thread progresses in RED links in ORANGE
3F-E Head ported polished larger flat faced Ferrea valves and flow tested before and after.
Con Rods for a Jaguar 4.2 straight 6 will replace the stock 2F rods
Pistons
JE Custom
ECU
Wolf V500
Turbo is a by Garrett GT30 82R
Valve Springs by Crow Part No4832
ARP Con Rod Bolts Part No 154-6001
Wastegate
Tial 44mm
Home Brew Intercooler Air to water
Jet Hot Ceramic Coatings
TLF Performance Parts 550cc Injectors
Davies Craig Electric Water Pump for the Intercooler
READING
New Features compares the 60 series 2F with the 62 3FE
Could you explain what that means for those of us who are dyno and metric challenged? I read it to say that peak torque is reached around 3000 rpm then levels off? I look forward to seeing this build up thread. :beer:
Peak Torque @ ~2000, peak HP @~3000-3500. (Lines are labeled P and T).
So you max out the RWHP at 100 (75 KW) correct?
With 368 Ft lbs of torque? (500 nm)
interesting..
I hit 140 hp and 220 ft lbs in my rig.
How did the torque numbers get so high without much increase in HP?
I'm assuming from the torque/power curves that this must have been with a stock camshaft.
Any induction, exhaust or compression changes to that engine?
What sort of loss are you attributing to the drivetrain (what sort of flywheel numbers do you think these approximate)?
Red is Gas Blue is LPG as for the Metric coversions sorry I'm imperially challenged :eek:
The original 2F was built and cammed for low down torque on LPG the head was skimmed and a few other bits. So it's tuned for LPG
This engine was built for torque not hp to turn 35's. Diffs are 4.556 too.
30 spline Longfileds in the front as we snapped a stock CV every trip out.
I've got a 2FE-T cooking on a back burner myself. Down the line a bit, so I'll be watching your build with interest.
Mark...
First the engine builder wants the 3F-E head which is stock to calculate the volume and compression from there he will if needed open it up.
It seem that to get more out of the turbo it may be better to de-compress the engine, rather than incress it. All this can be done while its been ported and polished.
Big learnig curve for myself here too.
New forged pistons will be needed as well as con rods. Crank I'm told is not an issue cam has not yet been discussed.
Now where is my credit card:eek:
I'll take pics of the 3F-E head before it goes to be machined and post up a full list of the modifications and after pics.
I don't think you will need any change to the connecting rods. Rod bolts are the weak link.
Nominal compression on a 2FE *should* work out right at 9.0:1 A little on the high side for a turbo, but it you're gonna be running an intercooler it should be okay.
Mark...
Mark...
Just off the phone with the turbo people they would like the engine to make around 8.0:1 so that's sorted if need be the head will be opened up to achive the required compression.
Also to run boost up to 20 psi I should have the the head or block O'ringed:D
I'm learning real fast.
Yeah I was assuming a max boost of 15 psi. I'd be happy as hell to make that work. ;)
Mark...
20 psi is nuts..
stick with 12-15 psi boost...
at 2000' elevation with a 8:1 compression ratio under 15 lbs of boost you will have an approximate effective compression ratio of almost 16:1
At 20 psi you are lookin at about 19:1...
But the concerns of a supercharge making cylinder pressure in conjunction with the pressure made by the compression of the piston moving up are not the same as an equal amount of presure made by compression alone. And an intercooler reduces the equvilency even further.Cylinder temps and detonation is not the same because of the amount of heat actually generated outside of the combustion chgamber and (in the case of an intercooler) shed there too. Not to say that even 12psi of boost is not a LOT. ;)
Mark...
yea.... my 87 supra turbo is running at what..... 6-8PSI?!?
Without adding the O'rings to the head or block the turbo people here only recommend a max of 10psi. It's seems the O'rings aid the cylinder head gasket so a higher boost can be run.
Like I said before I'm learning as I go. but for myself I think 15psi max would be the go rather than pushing the limits too far.
Other issues I have yet to address are fuel pumps and gas convertors to cope.
Considering that 15 psi will basically double your power... Yeah, I'd say that's plenty and I'd be more than happy to reach that level. (Don't forget that there's a lot of room to boost the power of a 2F BEFORE you get stated with boost!)
Before anyone lurking this thread jumps in with smarmy comments about polishing a turd or the old "put a smallblock in it"... Same reason mountains get climbed... Because it's there. ;)
Mark...
Mark...
Mark...
Mark...
I get all the V8 comments and not a cat in hells chance, the look on someones face with an all powerful V8, been beaten at comp by a 2F is PRICELESS:cheers:
Some of you may have seen this before its posted here and there on this forum. Me at play on my AT's
http://scotto.3rdrock4x4.com/MattMc40.mov
As you can see My current 2F turns 35's nicely:grinpimp:
