Quote: Landcruisersteve John, I'm a little confused.
I wish I could say that I'm just a little confused.
I no longer have a 25 in town so I can't compare. If you look at the rear backing plate on 25 and the one on your 1978 FJ40 I'm "guessing" you'll see the the one on the 40 is offset toward the inside. If this is the case, the only difference might be the backing plate and brake parts. I now have a FJ25 parts manual but was out bid for the early FJ40 one on
Ebay
. That way we could compare all the axle part numbers to find out the differences.
Quote: Landcruisersteve If I'm keeping the axle housings, axle shafts, the pumpkins and their respective offset that I've got already, why would I need to worry about the front diff?
You won't need to change the diffs. I'm just saying I have a complete front axle minus the diff and you could have any of the parts you needed, not that you would need the whole axle or diff.
Quote: Landcruisersteve You're saying that I'd only have to swap out the knuckles (and front backing plate) in the front . . . and just the backing plate in the rear, without having to change anything regarding the axles themselves??
You won't need to change the front axle housing with the inspection plate. The front inspection plate is something I would try to keep, the 25s and the very early 40s are the only one that came that way. That's what confused me about the 25 I have with 40 brakes. Still has the front inspection cover and a centered pumpkin. I know it can be done cause I have one. I guess my thought is if you have parts on your 25 brakes that won't stay adjusted and are worn out that this is the a way to keep the 25 axles but get your brakes fixed. If you had a dealer who still had the parts books you could try that too. I sure they wouldn't mind spending a hour or so with you just to have walk out without buying anything.
So have I got you more than just a little confused now.
I will at some point do this conversion myself. The early 40 I have the front axle was changed with a later one with no inspection plate. So I'm going to covert a 25 axle to a early 40 axle.
Did you ever try one of those brake shops that say they can do all four wheels for $99
If we could find the 40 parts book I'm sure this would be clear as mud
Steve, let's just do this the easy way, ship the 25 out to my cabin and I'll fix the brakes
John
