24V Alternator not charging/kicking on till 2,200 RPM--
Has anyone heard of this problem before?--Originally the alt would 'kick in' at about 1,000 RPM, then the dash warning light would go out and fuel water amber light as well---once the engine hit that RPM from then on it was charging, even at idle.
Took it in for a rebuild so that it was 'perfect and ready for a long trip', had the normal rebuild plus doubled the amps (re-wound--I believe about 50 amps now)--now the rebuild kicks on the first time at about 2,200 RPM, then charges fine after that--even at lower RPM--
ANY IDEAS...? IS THIS NORMAL--new to LC diesels..I don't think this is 'normal' but looking for ideas and thoughts--already taken it back to the alt shop and they re-worked it a bit..?
Thanks for any input/help!
LCDiesel60
LCDiesel60
