Ive got the battery equalizer wired up, but currently only for constant 12v. the 12v runs to a fuse block and then accessories get individually ran and fused from there. However I'd like to add a second fuse block for ignition-switched accessories. I know this would require a relay, but I'm really not sure how to make it work, or what relay (part number) I would need. Anybody have a simple diagram of how I might do this? I'm thinking I need 12v into it, 12v out of it, but then the "switch" power would have to be 24v. Is that even possible? It has to be.
So I wired things up as described, with a solenoid. I used this model: 24063-08 - Continuous Duty SPST Series - Standard High Current Relays from DC Solenoids and Relays - Littelfuse
12v in and out, 24v to one of the small posts. When it gets 24v to the small post, the solenoid doesn’t close the connection, allowing the 12v to pass to the other side. What am I doing wrong? Is it a malfunctioning solenoid?
No do. I shared chassis ground all the time with no issues. But Stones solution is still s good one. It was nearly 10 years ago, so o have no idea if it's still around.
But 120% you can share the ground with converters. I did it for 8 years.
The prohibition to share grounds on a 24 v to 12 v converter with a 24 v chassis ground came from the electrical engineer at Solar Controller. This is the guy who designed the box, not a sales guy reading off a pamphlet. My choice to run the equalizer instead if the converter is based on his expertise.
Some may have had good luck running shared grounds but I'm not going to risk the $ of my installed electronics based on their luck. I'll trust the math.
Hello All, Has anybody come up with a newer way to do this? The link in this post does not work.Switched to a 12v solenoid, and am running a second, very small, power converter on the ignition wire that goes to the switch on the solenoid so that it receives 12v to the switch. That seems to do the trick. I'm in business, with balanced batteries and 12v power, both constant and switched.![]()
