- Thread starter
- #21
Most of my kit is already built and ready to go.
Tools --
1/4" and 3/8 Metric socket set with extensions and ratchet (for 1/4 you can use an adapter from 3/8-1/4)
Breaker bar (or extended ratchet)
Wrenches - 10,12,14,17,21 (make sure you do not have any odd nuts)
Adjustable wrench (while most hate this, I find they work well when used right and in a pinch)
Pry bar (short)
Duct tape
Electrical tape
Spool of wire / wire stripper, side cutters, crimper / Electrical kit with ends, fuses
Hammer
Small drift or punch
Various Vice grips and pliers
Flathead/Philips screwdrivers (large and small lengths)
Headlamp (also get a good magnetic LED lamp as well)
Everything to change a tire and make sure it all is in working order
Good jumper cables
A sharp knife (utility, or otherwise)
Other
Rags or 2 rolls of shop towels
Bailing wire or stainless wire (in case you need to hold something in place)
Tie Wraps (Metal, plastic whatever)
Spares --
Hoses / clamps
Belts
Fuel filter (x2)
Vacuum line (small roll)
Plugs
Dist cap/ rotor
Fuel pump
Fluids
WD40
Kroll or PB blaster type of break oil
Engine oil
Gear oil
PS fluid
Brake Fluid
Coolant (50/50 mix)
Gasket maker
Crazy glue (works great to stop bleeding)
Extras I bring (I am going on a 4K trip this summer so I carry a few extras)
1/2" sockets with ratchet (common size)
Hub socket and rear axle socket (I have a FF)
Extra fuel
Washer fluid (hate running out)
Extra bulbs (front, rear external and head lights)
Tire repair kit
Extra engine, gear and other oils
Manual (paperback)
First air kit
Tarp
Appreciate the comprehensive list!
