So my son and I swapped the tc, tc cover, water/oil pumps, head/oil pan/valve cover gaskets, etc. Set the crank at TDC with the notch on the gear at the 6 o'clock (woodruff key at 12 o'clock) and the cam at 12 o'clock on the gear notch and markings on the chain in the proper teeth. for the distributor in inserted it to where the rotor lands around #1. The truck will not start. what am I missing?
Thanks,
ML
Thanks,
ML
