Anyone know the fueling strategy? More specifically, how does the base fueling map compare to open loop vs closed loop fueling?
Is the base map = to open loop?
Are closed loop +/- trim values always less than open loop?
In open loop, is the fuel quantity always greater than the fuel quantity delivered by a lean trim value given by the O2 in closed loop? OR if in closed loop and 02 sensor is reading lean, does the ECM trim up to put more fuel in than the open loop map?
I guess an even more simple way of asking these questions, does closed loop use a different base map to +/- fuel than is used for open loop base map?
