2017 what have you done to your 4 x 4 lately?
ThTime to go over the frame. Took some damage at Chinsman’s Gultch in Colorado
Thanks to @Zane i found the mandrel bends to get this done.
While I was under the car, saw that the skid plate took some damage. This picture shows the amount it bent.
Decided to try to make my own heat shield, I was looking around for aluminum to use and I found an old turkey fryer pot. So started cutting it up...
Then why did some 3/16 plate to create a double layer heat shield
Found a trick online use a zip tie to mark a perfect circle around a pipe
patrick asked for this info... in case anyone else wants extended hoses for thier 80 series.
LEFT FRONT HOSE REPLACEMENT:
38796 17-3/16" STOCK
38329 20-3/4"
38794 19-3/8"
38795 20-1/8"
RIGHT FRONT HOSE REPLACEMENT:
380231 11-1/8" STOCK
38790 15-1/4"
380163 14-3/4"
REAR HOSE REPLACEMENT:
38927 13-1/2" STOCK
380535 18-1/2"
Replaced front and rear door speakers with the pioneer replacements to keep the stock speaker grilles. I had to remove the “Y” on the rear grilles and the speakers fit with a few mm of clearance. I’m far from an audiophile but the new head unit and new speakers sound great compared to the old busted speakers. I have plenty of the neoprene for the gaskets if anyone local needs some.
Which Pioneer replacements? Model #? Specifically for fronts...thanks
