Looking for some help here. I just purchased a 2013 LX 570 with 131k miles. I had a PPI before purchase and tested and looked at as much as I could on this LX based on what I have read here prior to purchase. The build quality of this car is great and love driving it. I have had it 2 weeks and was planning to have all fluids changes next week and do the AHC fluid change. Well yesterday while running an errand I walk out the the drivers side under the rear door there is a big puddle and smoke from the AHC fluid. The LX is still in the N position and no warning lights came on the dash, When I got home it was still showing in the N position. With better light I checked it out this morning and the tank is empty and I see dripping around the rear globe but am unsure if it is coming from the globe or a hose. I can also see where it look wet around the shock and behind the rear tire on the frame. Assuming it just started spraying everything but can tell where it started. Trying to determine what parts I need to get ordered and can it be driven if the AHC pump can be disabled. Is my best guess the globe or shock or could I get luck and it just be a connection. Also is there a sub for the fluid that I can get local to fill the tank and try to determine where the leak started. I will get the OEM fluid once leak is fixed and bleed the whole system. I'm looking for options as there are no dealers open until after labor day and they may not even had stock of the fluid. I would like to narrow down what is leaking this weekend if possible.
