2006 LX470 - can't set maintenance reminders for later than 2022?
Subscribing to this bull**** to try and see if someone has a fix.
Subscribing to this bulls*** to try and see if someone has a fix.
Same here. My 2003 LC also has the 12/2022 calendar limit. I wonder how the current date was initially set at the factory...
Can you hop into the secret menu and check the Navi Info and Disc Info? (Mine attached)
Process:
1. Turn headlamp switch to off
2. Turn ignition to Run
3. Hold Info
4. Cycle park lamps on 3 times (Off > Lamp : Off > Lamp : Off > Lamp)
Process:
3. Hold Info
Hi but after open the secret menu there is something to do to change the dating simply using the menu or I must find an upgrade by disk or use the toyota techstream? in my country everytime goes into Toyota is an drama history thank you for help
Mrjet
Hi
Some of you managed to update the date beyond -/12/2022 :
I followed your instructions but I wasn't able to do anything, if you can explain to me how it's possible because not even Toyota /Lexus Officine knows anything.
I do this and appeares this on my screen
Thanks Mrjet
