2006 100 series with a bad vibration in the front right (1 Viewer)
Phoenix, AZ
I live in the Phoenix area and would like a recommendation for a good LC mechanic. Thanks in advance
  • downloadfile(1).PDF
  • downloadfile.PDF
Here are some better pics
Has the front wheels been balanced already? If you have a hydraulic jack lift up the front wheels and check for wheel bearing play. If you look those key words in YouTube it’ll give you a walkthrough on how to properly check it as well other components related to the suspension that may be related to the vibration you are experiencing. This will help you correctly diagnose the problem as well as if you decide to bring it to a mechanic you know if he is diagnosing it the same as well.
