2005 LX 470 - Largest tires on all factory rig?
Florida
I tried to search the forums but couldn’t find a specific answer.
Heading out for a 5k mile cross-country trek with trials to be done out West and on the way. Would like to know the largest tire I have that will maintain the smooth highway ride the LX offers yet will afford for stability off-road. Also plan to replace the factory rims and would like to know approach to the offset that may push the tire out of the wheel-well a bit to make it look a bit more aggressive.
Thanks and I appreciate any insights offered.
You can use Bora 30mm spacers to push the wheels out a bit, or get wheels with +30mm offset both will yield the same result. Tires 275/70/18 will fit nicely in the LX, shouldn't rub when in High mode offroading
Planning on the rims being Vision Valors which have a +18 offset and the tires would be Nitto Ridge Grapplers for total diameter of 33.19” with 275/70/18. Sound reasonable or what would you think about going a little wider to a 285 while taking into consideration I’d like to keep a smooth highway ride?
33inch tires. it is known. (GoT reference)
so if you are on 18s, 275/70/18 which are in abundant use on stock 100s.
