ok so i have found out the the previous owner for some reason took out the entire relay assembly for the ac condenser fan and fuse. Hence why mine is not working. Tried to find one online and everything i find does not look like it will fit the plug, my car is a 2001 LX470 and it seems to look like a different connector than the relays i can find for the 99-2000. They are all 4 pin relays and plugs with 4pin, my plug has 5 pin, one is a ground, i was going to wire in my own relay since i couldnt find the exact part that looks to fit my plug but the wiring diagram (from my lexus wiring FSM) shows that the relay is a 4 terminal.
I did trace all the wires i could
obviously the thick wires are the ones to supply fan with power, the 2 thin ones (not ground) 1 of them goes the the 3 stage pressure switch and the other one (according to the manual) goes the the Mag Clutch relay. and the black and white one is ground.
i got 14v from one of the thin wires to ground while engine was on but it would not go off it continued to supply 14v even when high pressure line was below 220psi.
any ideas (best scenario would be finding this 5pin relay)
