Does anyone have a lift they want to get rid of or have any suggestions. I've searched but would like local feedback/support.
Groundhog said:Does anyone have a lift they want to get rid of or have any suggestions. I've searched but would like local feedback/support.
Spring over, cut n turn, some shims for the rear pinion angle, some new shackles/bushings, good to go.
1911 said:Wouldn't a spring-over net quite a bit more than 2-3" of lift, even using flat springs? I've never done one on a 40 mind you, just curious.
I'm happy with my 3"-lift Alcan springs but it took some tweaking to get everything right. Still not positive my shocks are the best length.
SOA is cheap....kind of...and this dude asked for cheap. A lift kit, per se, is expensive, though, IMHO, the net reults are better.
i never asked for cheap. just looking if someone had upgraded and had extra goodies.
keep in mind this rig has a SBC (weight/distribution?) and id like to be able to pull a small popup trailer.
SOA questions:
what needs to be lengthened drive line, control arm, etc????
I assume you mean drag link. drive shafts- yes, drag link- only if you want the steering wheel centered.
stock springs?
yes.
is this set up side hill wobbly for a SWB?
mine is set up a fair bit higher than a regular SOA, I often put it off camber very far. I am a bit wider than stock , but higher too.I wouldn't worry about that, it will go farther over than you are comfortable with.
SUA questions:
better stability?
around corners on the street, yes.
small lift with shackle reversal=no need for cut/turn?
I never cut and turned mine when it had stock axles. really depends on your drive train and how long the front dive shaft will be.
quicker?
probably
ive read the Safari springs are stiff but they have a SUA Crawler setup with SR and extended shock towers that looks like a good stable set up.
I should've gone soa!"
My goal is to end up with a rig that can pull a trailer big enough for two people and my creeps(pics of creeps to follow) long distance ie:Ouray, Moab, Chama etc. upon reaching said destination be able to hit trails that fall just short of rock crawling. This 40 is too nice to thrash. Im trying to get a little more lift / articulation just short of soa...just enough to get me into those spots where I'm saying "Damn I'm destroying this beautiful rig, I should've gone soa!"
I personally think it is the way to go especially if you have a SBC to pull it around.
that is exactly how I started when I bought my 40. bought stock, and wheeled it. soon it had 3" lift and 33's. wheeling was fun getting into harder trails, but got to a few spots I couldn't get past. need lockers and power steering...got 'em, and got to the next spots I couldn't get past. need SOA and 36" tires...got 'em, now on a whole new level of wheeling and blew the engine (no fault of the trails), chevy LT1, auto tranny, 1 ton axles and 40" tires...
could've saved a bunch of money by skipping a few steps. switched lift type, locker type, power steering type once and upgraded twice, tires size went up 3 times...Josh is probably right, it's only a matter of time.
that said, the SUA lift sounds great for your current needs. OME and Alcan are probably the best quality wise.
and then a trailer, followed by a tow rig.....
