Mine was the same, once I readjusted to cross-level it sat even on all 4 corners.Sidenote on all of this, after the king spring install, the passenger side of my truck is 1/2 inch higher than the driver side, and I can't get it to even out. Have cycled AHC multiple times, adjusted sensors and still no luck. Stumped.
Checking your cross level is fairly simple. You need to get on techstream and make sure your front L and R sensor are close to the same values. Once that's been checked or you have adjusted the sensors to be within the same range, then you need to adjust the T-bars accordingly. My ps was higher than my ds, so I loosened the passenger t-bar while tightening the driver side t-bar. I would do one or two turns at a time, then go for a drive and re measure. Slowly the sides will start to level out. I kept adjusting until my heights on both sides were the same. I hope this makes sense.Can u explain?
What are you trying to achieve? Lower front pressure? cross level ?{please search the term "cross level" posted by me for the correct FSM approach} the right ride height or all three?Has anyone watching this thread tried installing torsion bars from a non--AHC truck?
My pressures are OK, despite being on the high side, but I get very little adjustment with sensor movement. Existing torsion bars are maxed out.
To set cross level all you need is a tape measure and 30mm socket; don't touch the height sensors whilst setting cross level at the risk of chasing your tail and becoming increasingly frustrated. Height sensor feedback follows the upper arm to chassis displacement and can be nulled pretty much anywhere so it's much better (per FSM and experience) to physically set the actual cross height then adjust the sensor to read 0 or as near 0 as practical at your selected N height. Adjusting cross level via sensor feedback only works if you're sensors are perfectly aligned as if it just rolled out of the factory.Have the same issue, hoping it resolves itself after some miles. Should have checked this weekend slipped my mind.
I also need to get TS up and running so I can do the procedure DirtDawg suggested above.
275/70r18 BFG KO2sDirtDawg, what size tires are you running with this set up?
