- Thread starter
- #101
do they rub?
What he said^ I did experience some rubbing on the rear of the front fender well splash guard, but that was remedied by heating and flattening it.No. They won't rub at stock height.
do they rub?
do they rub?
Just FYI you can rent a pitman arm puller from vatozone for "free", but also a good tool to have around.Well I have everything purchased except the coil springs. I am at over $300 already into this. Man I hope it works out good! I had to buy a Pittman Arm Puller and Techstream for 64 bit windows, so that added $60 to the overall price. Going to have to hold off on the springs until later this month, my wife isn't going to be happy when she sees all this!
With my neutral ride height (fender to hub center) at 21.75" my suspension looks like this on the ground:
With the front tires off the ground, without restarting the truck, my measured height was 24.75" and looks like this:
I failed to mention, my lift consists of 2" height achieved by sensor lift, slee diff drop, Japan 4x4 AHC actuator spacers, SPC upper control arms.
YesSo I just thought of a question. With the sensor install, does the comfort/sport knob still do it's job?
You are right at the 1.5" mark. Steering may feel different or weird if you have yet to get an alignment. You NEED an alignment.Just curious what everyone is measuring from hub to fender after just doing the sensor adjustments no spacers. I have ktrs 79 Springs on the rear.
I'm currently at 21“ front 22“ rear going by memory factory is 19.5/20.5". I'm happy to achieve a 1.5“ lift.
my steering is starting to be affected, I felt a little binding at full lock and one click from my cv as soon as I pulled out of my driveway after doing the lift.
Will a diff drop fix my cv issues with the binding?
When the steering wheel was turned say 90% left it was a similar feeling when a tire is stuck in a rut and the trail takes the wheel from your hand and continued to turn.
It only happend once, and maybe I'm over reacting but I'm not going to try turn full lock till my differential drop comes in.
My other problem is the 275/65/18 tires are starting to look small with the lift. Wish I went with a 33“.
It will be fine on stock springs. Until you add any sort of load. Then you will wish you had done Kings.
Honestly that's a huge duplication of effort. Unless you see negative effects after adjusting the sensors, wait until you have the springs and then do both springs and spacers.
The sensor lift is a crazy simple deal. It literally takes 10 mins with 2 10mm wrenches.
You can just order the kings off eBay. It says who I sourced them from in the first post.And since I am going to change the AHC fluid at the same time, I should probably wait until I get the springs here. Has anybody found a place in the U.S. that has these springs, or something that is the equivalent? OME maybe?
