1UZ-FE/2UZ-FE/3UZ-FE with manual transmission and Speeduino ECU. (1 Viewer)
What tranny was on your 1uz original? W5 series. I need a bell housing also. What bolt pattern is your template?
I would definitely be interested in selling the adapters but I don’t want to sell something idk if it works or not. And the transmission was actually from a sequoia (2uz auto) if I remember correctly. I went and pulled a bell housing off in a pull a part yard.
The bolt pattern for the adapter just hooks to the ears on the trans and then to the holes that hole on the bell housing. Idk what the exact measurements are.
Very nice work! Are you going to run the hyro thrust bearing?
That’s the plan right now. I was going to run the cj5 clutch setup I saw on the other thread but then I saw this thread so I am unsure of what setup to run now. I want something that is easy so people can actually buy the clutch parts and an adapter for reasonable prices.
I don’t see an opening for a clutch fork?
I would go GM internal slave and match it with my Wilwood 7/8” MC kit. That setup has worked really well for me and a few customer trucks
I was planning on drilling some holes on the side of the bellhousing for hydraulic lines and use a hydraulic throw out bearing.
I looked into going manual when I started my swap but decided to stay auto. There is an OE bellhousing out there but I lost the part no. I used the Lexus SC400 trans with a Tundra output shaft and a 99 200 series T Case. I am pleased with how my 62 drives but of course a little more power would be nice. That's why I plan on installing an M90 from a T Bird onto my engine which happens to be a 94 with the good rods. I am closer to my 80 series full floater rear axle swap than the blower install.
How is the build going?
Slowly.. I got my Saginaw box mocked up and need to finish it. But for the engine and trans I was talking with California Custom Clutches and he can the pressure plate and friction disc but i have not ordered yet because I am still trying to figure out the throw out bearing.
Hey check out Slow car salon on YouTube this guy is installing the throw out bearing on a 1uz. Ep5 is the video where he is doing the job. Great info
