- Joined
- Dec 3, 2009
- Threads
- 17
- Messages
- 145
Isnt that oil being circulated though the engine?
Can someone explain why the injection pump governor is different between the auto-trans and manual trans models?
My truck has an engine out of an HJ60 auto, which I have converted to connect to a manual transmission, keeping the original auto injection pump. No EDIC, no diaphragm to wear out - why isn't this the standard issue pump? What advantage is there to having the diaphragm/EDIC set up over the simplicity of the mechanical governor and engine shut-off with just one vacuum switch?
Wow, learned something new again.
Thanks Lowenbrau and Tom!
I've owned my HJ60 for almost 11 years now and I've never un-wound that bung
And I doubt if the previous owner did either. Could be interesting to see how much oil is trapped in there.
fellas........
I'm not sure that the non diaphragm system is superior at all. I think the diaphragm meters the fuel/air much better. The auto 2H is always smokier................. I think Toyota dropped the diaphragm when they mated the A440 to the 2H because the 2H needed a transmission kickdown cable directly connected to the fuel rail and that wasn't practical if the fuel rail wasn't connected to the driver's foot.
Yes, mine is a little smokier - I put that down to the fact that the injector pump for the auto trans connected engines puts out more fuel at each rack setting, especially at start-up.
Would this not be a good candidate for a turbo, given that people who fit turbo's usually end up turning the fuel up a little?
I was completely unaware that this plug on my BJ40s injector pump was there for draining engine oil that leaks through internal seals into the diaphragm enclosure (into the governor housing).
On my 1987 BJ70 with 3B, the injector pump does not have a drain plug that must be periodically opened. Instead, Toyota installed a hose fitting and ran a very small drainage hose, complete with hose bracket. Why not just add this and forget about when to drain the excess oil from the IP?
FYI, not my modification - came new from factory just exactly like this.
But figure anyone could do this easily.
Hose is open ended. Just drips to ground.
I have never noticed any drips, since so little oil accumulates.
Strange!
I would have expected that hose to suck in air (and dirt) whenever your engine's running.
(Not a big flow .... But enough to suck in fine dust ... I'd have thought.)
So I prefer the plug idea.
