1st & 2nd gear won’t engage (1 Viewer)
Oroville, CA
i have R, 3rd, and 4th on the 79’. Truck has not been driven for 15 years. Tried in 4H, n, and 4L. Have started it in 4th a couple times and it jumps forward. everything worked great before. Any tips and tricks bfore i remove plate and inspect clutch? slave and master are new.
does it "feel" like it engages in 1 and 2?
wonder if there is an issue with the shift gate or knub on the stalk?
negative. it is solid, won’t go at all.
it is not the clutch if the rig will move in R or 3 and 4
wonder if after sitting so long the shift rail is froze/rusted for 1 and 2
remove the tunnel cover and remove the shifter stalk and see if the rail can be moved with a long screw driver or prybar
not sure you can remove the top of the trans from inside on a 79, you could also remove the entire top plate and see if the shift rail will move
the shaft appears to be siezed with a little corrosion. i dont know the name of these parts sorry.
i plan on getting a mallet and a screw driver to free this. also put some oil in the ball bearing area might get down to shaft.
everything appears to look good otherwise. not bad for 134k
let me know if there is anything else to do while this is open. gasket will need replaced
Check to see if the proper detent balls are under the springs
90360-10003 Ball $1.193
90501-14772 Spring Compression $4.003
so it was about an hour or more of tapping with a punch, spraying pb blaster, and rocking it. 1st gear was the hardest to get to free up. It was siezed good. A good large straight slot screw driver to pry helped too.
thanks guys. one of the balls (R) was rusted a bit so I will replace it, as well as the gasket and fluid. this is a great time to replace fluid with it open.
I’m guessing there was just a little more wear on 1 and 2 and for some reason they didnt get fully coated in oil before storage.
So I ended up changing the transmission fluid and filling through the top. Dad ended up changing the T-case fluid a few days later.
I now leak 90W oil right where the oil pan butts up against the transmission housing (I think). This only occurs while driving, saw some splashes down the diffs etc., and puddles where I stopped to open my gates.
Read a bunch up on this but need some clarification/help. If one or both were over-filled could this cause the leak with too much pressure? Some say there is a tranny breather on top where I took It apart but I didnt see anything. I plan on checking the TC breather hose too.
Could this be TC/Tranny gasket? Why only when driving? Literally parked when hot, placed bucket underneath and only got a few drips. Could I have screwed something up on top? I replaced seal. and this was very straightforward 8 bolts and some springs to re-install cover plate.
Some folks have installed a bypass hose between the fill plugs on the transmission and transfer case to equalize the gear oil.
if it is overfull, just take out the gearbox fill plug (LHS near the back of the transmission) and any excess oil will run out. Same with the transfer case, take out the fill plug and see if oil flows out.
The transfer breather vent is a small sheet metal nipple nearest the top of the transfer case (the flat bit bolted on with 8 bolts) that has the Hi/Low transfer lever on it.
