1PZ warm engine knock - help (1 Viewer)
Rangiora, New Zealand
my 1PZ sounds its usual rattly self when cold. But when warmed up, cruising at around 55km/hr, there is a metallic knocking sound coming from the middle left hand side of the engine (its a RHD truck). Its irregular too, sort of sounds like a train on a track. Took it to mechanic, and he said it wasn't mechanical and not to worry (he only did a listen test). I can induce the same noise when warm and I wind up the idle when stationary. Any ideas? :confused:
Take it to a different mechanic maybe?
cheers
runs like a dream! No vibration, still pulls well. Only makes the noise when at a certain rpm. Sounds like a heat shield knocking back and forth, like tapping a set of drum sticks on a metal sheet - bizarre. I think because I can induce the sound when stationary and increasing the revs to a certain point, that it must be mechanical.
2 piece flywheel springs ... pull the clutch and take a look. it shouldn't grenade anytime soon but it is a nasty sound.
hi Wayne
been there done that. My 2 piece exploded last year. and you're right about the sound!. Now have single mass flywheel. So its not that.
cheers
did the sounds start shortly after the single mass was installed?
could it be the springs in the clutch disc then?
could it be the 2 piece pully on the front?
Valve set probably needs to be done. Can sound pretty bad at certain RPM ranges.
Sometimes the injection pump will make noise as well.
~John
