1KZ-TE Manual Transmission Swap (2 Viewers)
British columbia, Canada
Hi all,
I am looking to do a manual transmission swap to my currently auto 1kz 94 Surf. Has anyone else done this using donor parts from an NA 4runner? I have a parts 3.0 2nd gen 4runner with a R150F. My main concern is that the Bellhousing currently attaching my 1KZ to it's auto trans wont bolt onto the R150F. Next I'm worried that the clutch fork currently on the r150f wont be compatible with the 1kz clutch hardware I put in, or if I source a 1kz clutch fork I'm not sure if it will be compatible with the r150F. I've scoured the internet for hours and can't find anything, any insight would be appreciated. If I go through with it I will be sure to document the process.
Cheers
You will need the 1KZ/R150 bellhousing and the associated clutch parts, including clutch fork and slave cylinder. The rest of the transmission should be compatible, including the input shaft as long as you stay with a 3.0 variant and not 3.4.
The clutch fork is 31204-60090, throwout bearing 31230-60170, slave cylinder 31470-60201, and bellhousing 31111-60270. The stiffener plates that bolt between the engine and transmission would be good to have as well: 33118-60050 and 33119-60050.
Are you sure about the bellhousing? Did the Manual transmission 1kzs have different bellhousings to the autos? I haven't really found anything online about whether it would work or not, but would really muck up my plans if I need to track down a bellhousing.
Quite sure. Bellhousings are both engine and transmission specific, at least in the Toyota world. The 1KZ/A343f bellhousing is 35111-60080.
For reference, here is a 1KZ/A343f bellhousing:
This is a 3VZ/R150f bellhousing:
As you can see, the bellhousing to transmission bolt pattern is quite different between the two. Also, on the R150 the hole for the clutch arm and it’s pivot are both in the bellhousing.
I realise I'm kinda late to the party, but I'm considering a manual to automatic conversion on a 1kz-te Surf.
My Mrs has arthritis in her wrist which means manuals are out for her now. We may be able to do a swap.
I hope that this thread is still active. I have a 95 KZJ78 (auto) 1kz-te engine. Ive debated about doing a auto > manual swap. I already upgraded to a (manual style radiator and a trans-cooler).
Would an R150 be the manual trans I need to find for this? Or did a different manual trans come stock in 70 series manual land cruisers.
Thanks gents!
An R150f would work, but the KZJ78 originally came with an R151f with a lower 1st and 2nd gear ratio to match its 4.30:1 differentials.
Are you still interested in a manual to auto swap.
Im interested in a auto to manual swap i currently have
1kz-te/a343f.
Looking to swap to
R151F
