You are talking about the dash gauge, aren't you? They are very simple indeed and not very accurate, but very sturdy. Neat thing, discovering that you can actually adjust the bimetal's response. Is there a variable resistor inline with the bimetal heating coil?
It would be very interesting to start a 'mod your low reading OEM oil gauge', as no one seems to have done anything like what was done to improve the OEM temp guage...
Yes I'm talking about the in-dash guage.
The setting is done by a notch, not a resistor.
The bi-metal switch 'switches' as it get heated by the current, running through the metal of the bi-metal. (Or a small heating-coil around it, ...cannot remember).
The amount of heating needed to get the bi-metal make the 'switch' is depending on the pressure with which this bi-metal's contact is pressing on the opposite contact.
This pressure is depending on two values.
The first one is the pressure that the oil excerts on a (metal)membrane.
The second one is the notch.
This notch can be adjusted with a small screwdriver. Cannot remember or it was an excentric part or a matter of 'tightning' a nut. To my opinion that's the way to go.
Problem is getting to the notch -adjuster. After opening the sensor it will be hard to get it properly closed (sealing) again because you have to bend away parts of the cap in the process of opening it up.
Maybe drilling a hole in the top of the cap, near the connection point can shed some light on it as where the adjuster is located. Probably a second hole is neccessary then because this adjuster is fairly small.
Some time ago (2-3 years?) I've read about people 'adjusting' the indication by adding a resistor parallel to the sensor.
All this does is providing some current flowing past the sensor. This will give some 'pressure' indicated on the guage, even when the engine is 'off' but the indication with engine on is higher.
This resistor can be placed either near the guage or the sensor. Near the guage, use the post connected to the wire that leads to the sensor. The other end of the resistor to be connected to ground.
Near the sensor, connect the resistor to the post the wire is connected to and the other end of the resistor to the sensor-body which is grounded.
Having the resistor near the guage has the advantage of it being in a more or less guarded area, but involves a bit of work.
Near the sensor is an easy fit, but it then is prone to damage and wear.
Dunno about the value for that resistor. Would start by trial and error with several hundreds (thousands to be completely safe) of Ohm's. Think you'll need 1/2 or 1 Watt.(can start with 1/4 or 1/8 Watt to establish the needed value and later on buy the same value in the havier range if it heats up too much)
Just connect it to the sensor wire at the sensor end, the other end of the resistor to ground (Contact on!) and see what happens. If the indication rises too much take a higher value for the resistor. If too low, a lower value. Make sure the resitor doesn't get hot. If so, take one that can carry a higher load.
