1HZ into HJ60 4spd
Australia
Hey guys, It's been awhile but i found my way back here.:)
I am looking at putting a 1HZ into my Hj60. I have searched and found heaps of useful info thanks everybody!.
However there are question aplenty that i could not find covered.
Firstly, as silly as it may seem, Can i bolt the 1HZ up to my 4spd or does it have to be a 5spd?
If so what about the clutch/flywheel?
Things like engine mounts and gauges are no problem for me, it's just the knowledge from experience that i am chasing to ease some heart ache along the way.
The engine i hope to get is just a long motor, no manifolds, so i have a bit of work ahead of me. If the plan goes right it will end up a turbo 1HZ bobbed single cab ute.
It's currently a supercharged 2H. Twin locked. 4.88 diffs etc etc.....
I can't wait to experience the 1HZ in the light weight bobbed ute!..
Do you require a certain amount of posts before you can post images?? if not i'll get some up!
Any help would be appreciated.
Current truck..
The "New" truck.
Hmmm. I thought someone might know something!
I wish I knew more about the 1HZ, but alas they are rare here in NA. Suggest you check out the diesel tech forum - those guys know a lot more about diesels. Hopefully one of them can help you!
You will need the 21 spline 5 speed and the clutch that goes with iT.
Unless the the long motor is really cheap I would consider getting a motor that is complete,maybe one with the gerabox
Buying a pump ,injectors/lines ,flywheel and all the other little things separately gives me a headache just thinking about it.
Basically it will cost a lot of money,possibly more than a good used complete motor.
I like your bull/winch bar even though its a little close to the radiator.Is it off a 75 series?
How about some pics and info about the supercharged 2H?
The engine i have was free. It has injectors, pump, waterpump, etc. need manifolds and electrics. There easily come by.
The bull bar i made. The winch looks closer to the radiator in the pic. There is actually 4 inches clearance between the winch housing and the radiator. And before anyone ask's, No i wont make another one. It was a prick of a job.....
Thanks for the info on the 5Spd. I thought as much but was hoping not!
I have been doing som reseach on the same project...
In orden to make the 1HZ fit in mine HJ60 w. H55F transmission, I needed a new input shaft, as the one I have has the wrong spline and wrong lenght.
You will need a new bellhousing, as the starte is on the opposite side of the engine, compared to the 2H.
Besides that there are some minor things...
But read this: http://people.clemson.edu/~gfujii/rides_pgs/cruiser/1hzswap/1hzswap.htm
Much information there :)
Basically it says.. Get the engine, the H55F and T-case.. It will save a LOT of work.
Good luck with the project... I hope to do the same soon :)
Cheers Dan
Thanks Guys, I am a little confused with the H55, H55f thing. What are the differences and which one do i need? Are there different splined and length input shafts on the same G/box codes???
Pic of supercharger..
Found this :
H55F = Cruiser 5spd in Canada
H42 = Cruiser 4spd in N/A
H41 = Cruiser 4spd with the H55F granny 1st gear (basically an H55F without the 5th gear hanging off the back).
http://bb.bc4x4.com/showthread.php?threadid=56391&goto=nextoldest
afaik, the H55F HJ60 will not fit due to different spline count and lenght, but it should be possible to change inputshaft så that it fits.
I am not sure if the H42 or H41 case will fit.
Think I would write a mail to somebody who knows about t-cases...
ex http://www.marlincrawler.com :)
cheers Dan
Yes,this gearbox has 3 different spline count and length for the H55f.
There is one for the petrol and 2H diesel,another for the B diesel,and another for the 1HZ.
You can swap input shafts and bell housing but in oz its easier just to get the correct gearbox.
The t/cases are interchangeable as long as you have the complete t/case.
You cant mix pre/post late 85 t/case parts
Great pics ,what kind of blower is it ,TRD ??
How much differnce does it make and any problems with it?
I want to fit a Sprintex blower to my 1HZ. they make a kit for the 1HZ.
Thanks :) That defenatly cleared som things for me...
It means that I have to get a new T-case.. mine is from 83..
Bommer...
But thanks :)
Cheers Dan
Oooooo my !!!!!!!!!!!!!!!!!!!!!!!!
please details .. !!!!!!!!
