Hi Folks,
Putting on a new 1HZ head while re-using a few components and have some questions. If anyone has input on the following, I'd greatly appreciate it.
Lifters - In a very unfortunate event, I got the valve lifters/cups completely out of order when removing them. My assumption is they are identical regardless of the valve, but have worn differently. Am I fated to measure clearance and re-shim every single one? Or is there a trick I could use to try to get them back into order and not have to drastically re-shim? Valves and springs are new, camshaft is from the old head.
Camshaft and bearings - as the head is new, how risky would it be to install the old camshaft (assuming it meets tolerances in the service manual) onto the new head's fresh bearings?
Injection Nozzles - the service manual also mentions keeping these in order, however in my infinite wisdom i definitely did not do that. As long as they've been tested, how important is the cylinder order here??
