For Sale 1HDT w/ auto trans and transfer case
To clarify, motor has not been torn down. Motor has a misfire, and either a cracked piston or ring land based on extensive research. It does run and has been moved up and down the hill at my mechanic's shop on a daily bases. Motor will be pulled out next week and a better diagnoses will be given or sold as is.
I didn't want to tear it apart because I already did that to 1 motor and the cost to rebuild to my liking when up the roof. Hence why I just bought a complete motor from oversea to gamble on that.
I am selling the transmission complete with the motor and all the stuff bolted to it and will not separate.
I think this is a great deal. Probably just needs some light machine work, rings and pistons. For that you get a nearly complete 1HDT/5-speed 80 series swap. This 5-speed is an H150. Just as strong as the H151 (same case, bearings, etc), but has a nice low 4.529:1 first gear. If you were to add the 3:1 transfer case... you could have a 55:1 crawl ratio. Pretty respectable crawl ratio.
heya- if your cruiser mechanic pulls it and gives it a closer inspection diagnosis- id be real interested and could bring my cruiser down to him for added install work of he is able? my preference is to simply know better what its going to take $ wise to remedy the miss/ring/ piston issue. im up to my ears in other projects- so this would take a bunch off my plate if he can do the work and has time? where is he located? pasadena or other?
Truck is in Walnut.
To have this installed you still will need, the pedals, clutch master, and some other random parts outside of the motor/trans. I don't know if my mechanic wants to take on this project but PM me for the mechanic's info if you would like to discuss with him.
Am I insane for wanting to buy this beast and put it in a 40?
Thought so. I'll keep looking for that unicorn also known as a 3b turbo with a H55F and split case.
Change the thread title to match transmission available!
