Diesels used in vehicles are not intended to be held at high RPMs for extended periods of time like a boat or tractor engine.
I do not know about this statement ... quite a few modern diesel engines are mostly spec'd to run at or near the governed engine speed. The Cummins ISC 330 in my Haulmark motorhome has a recommended cruise RPM of 1950 - 2150 rpm with a governed speed of 2200 (2400 for engine braking). The same pretty much holds true for the ISB used in the Ram pickups.
Yes, having a heat sink the size of the ocean (literally) helps cool a marine diesel, but quite a few automotive and truck diesels are designed to be run flat out or close to it for extended periods of time, assuming collant and oil temps stay in range.
My $0.02 based upon a few years experience with light duty and medium duty diesel engines for on road applications ...
<required yota tech content> even the smaller 3 and 4 cylinder Yanmars utilize the same filter as some of the Toyota diesels </ tech content>
