1HD-FTE and A750 5-speed auto 80-Series Install Writeup
Hmmm... what did it look like? I don't think I have any sort of external tach converter. I did unwrap and reorganize the harness quite a bit and re-wrapped it in harness tape as I was a little underwhelmed by some of the finishing touches.
And yes, I do have cruise working with the factory stalk... but getting the light on the dash to work will require a little more fiddling. Bryan makes a nice multiplex to analog converter for the Cruise, PWR, and 2nd Start light, but I was unable to get it to work. We are theorizing that my ECU may be sending a slightly different string of code and he will have to play with it in person to get it working. So, right now my cruise works, PWR, and 2nd Start all work, but I have no indicator lights.
Very nice description and good approach on the projct. I am facing the same with more or less 340t mls on the clock of my US LX I intent to swap for the 1HD-FTE/A750F power-pack. We have a lot of choice of on HDJ100 from northern europe with low milage but rusted body. Thanks for that brillant manual.
Nice write up, obviously you don't have to answer if it's a grey area, but what are the legalities of importing rolling frames that are newer than 25 years old? Thanks.
Thanks. As to the importation of rolling frames, I'm pretty sure you are right... it's a grey area. Generally speaking, I believe it's a no-go but there are people who occasionally find a way to get something in the US. In my case, I didn't import the frame - I was told they were armored DoD trucks which were de-mil'ed.
You let me know if you happen to run across a late production Euro FTE truck with a 5 speed manual transmission being dismantled!
Man, what a lucky find! I'm looking at importing an HDJ100, the 5 speed transmission I'm sure is a nice upgrade!!
I sincerely think someone could make a good side business, importing packages of "Swap ready 1HD-FTE with harness, ecu, etc."... since they're just rusting to pieces over there in Europe. Instead of half cuts, dismantle it down to the essentials to save on shipping. Maybe have certain optional components (trans, transfer case, airbox... so on). I can't be the only one better equipped to handle a crated engine than half a vehicle.
If I were more ambitious I'd tackle it myself, but I already have one job I'm too lazy to do. 😆
Here is one of them ... dealing HDJ100 from Danmark. He is always getting a bunch of these frequently
https://home.mobile.de/JKRAUSEAUTOMOBILE#contact
I just realized I've got 40,000 miles on this FTE since March of 2023. I drive the piss out of this thing and absolutely love it.
Here are some photos from the last two years to celebrate the occasion. Cheers, you sickos!
Nice!!!! Great looking truck! I just imported a 1998 HDJ100 for my swap
Really nice, unleash the beast.
THAT is what it is all about.
Cheers
I'm going to take a moment and make a comment for the benefit of anyone experiencing a similar issue.
Ok, I've had a transmission-related vibration pretty much since I finished the conversion. The symptoms were a very noticeable vibration when sitting at idle in Drive or Reverse. Several friends and I explored several theories; over/underfilled transmission fluid?; failing line pressure solenoid?; contact between the shifter and tunnel?; loose engine mount?; ECM related errors?; bad torque converter?; loose flex plate?; etc. Despite hours of troubleshooting, nothing seem to be directly linked to this vibration.
Recently, while using a buddies lift to do some maintenance, we noticed the transmission isolator mount bolt head showed signs of rubbing the transmission crossmember mount. WTF? Rut-row. Ah HA!
When I did the conversion, I used a hole saw to clearance the transmission crossmember. Although this hole looked large enough to pass the nut head through, apparently the drivetrain moves enough on the rubber isolators to allow contact under certain conditions. As soon as we radiused it to provide more clearance all weird and intermittent driveline vibration issues are now gone. Frickin' wow.
I can't believe it took me two years to solve this one. So for anyone using a 100-Series transmission isolator with that big-ass nut in the middle, make sure you drill a hole large enough to provide a clearance margin due to drivetrain movement.
:doh:
Now if I could figure out the occasional blip I get at cold start, it'll be perfect.
I have been seeing conflicting info on fueling, so I wanted to verify your setup for the fueling/fuel supply:
For the fuel system, all that was required was dropping the fuel tank and removing the filler neck (which required cutting into two pieces). The restrictor was cut out of the fuel neck and I swapped the EFI petrol fuel pump assembly with a diesel specific pickup I found on the classifieds. I made up my own hard lines using the original as a template.
Did you use any sort of lift pump/feed pump, or is the primary hi-P pump on the motor sufficient for the long pull from the fuel tank, through the filters to the primary hi-P fuel pump?
The IP is capable of pulling the fuel it needs. If you decide to put in a lift pump, be sure you don't unintentionally create a failure point. Many fuel pumps will not allow fuel to pass through when not running. You don't want to get stranded because the pump you didn't need to begin with is dead.
