Wanted 1HD-FT and 1HD-FTE Conversion Parts
lelandEOD
Dayton, Nevada
Engines have been sourced; thanks! However, I'm still on the hunt for conversion parts!
-HDJ80 (solid axle) 1HD oil pan (with sensor port)
-HDJ80 vacuum canister
-HDJ80 fuel filter bracket
-HDJ80 air cleaner lid
-1HD 80-Series manual transmission center consoles
-HDJ80 clutch master/slave hydraulic lines
-HDJ80 left or right hand drive manual clutch pedal assemblies
Looking for:
- 80-Series left or right hand drive manual clutch pedal assemblies
- 80-Series clutch master/slave cylinders and hydraulic lines
- 80-Series diesel tachometers
- 12v starter motors
- Used intercoolers
- 80/100 Series 1HD air cleaner assemblies
- 80-Series manual center consoles
- A442F electronic transmissions and computers
- A442F shifter assemblies
Mechanical parts are tricky to ship from overseas. Can get you 80 series diesel clusters with tachs.
Looking for:
I have a HDJ81 air cleaner lid, both hoses, and the pipe between them I bought for a build and am not using. All new in Toyota bags
Looking for:
- Used intercoolers
@Bardiya could hook you up with some of that I bet
Looking for 1HD-FTE complete engines, transmissions, and engine/conversion parts. PM me with any leads!
I have all that except the E 5 speed triple lockers safari intercooler stainless 3 inch exhaust etc173000 KM or 110,000 miles You can call or PM or send number to discuss Jan 7800 880 8003
-HDJ80 (solid axle) 1HD oil pan and pickup tube
-HDJ80 radiator fan shrouds
-HDJ80 clutch master/slave cylinders and hydraulic lines
-1HD 12v starter motors
I believe the radiator shrouds are still available on partsouq.com that's where I got mine.
The manual center console is no longer made but @jomelo might have an aftermarket solution for you.
Where did you source the motor if you don't mind sharing?
I’ve got a 1HD-T oil pick up tube/ strainer assy if you still need one
and pretty sure I have HDJ81 fan shroud
I should have:
-HDJ80 left or right-hand drive manual clutch pedal assemblies
PM me for more details.
I have a used 80 rhd spring assist clutch pedal assembly.
I think Akella is hooking it up with the pedal cluster, but thanks. I just realized I do need a HDJ80 vacuum canister so I'm adding that to the list. If you have one, please let me know!
