As the title indicates, my timing tensioner is stuck in the head and Im looking for suggestions to get it out.
Back story, I just finished replacing the bottom end with a Toyota built bottom end. When I was taking everything apart, I couldn't get the timing chain tensioner out so I just worked around it. As I was putting everything back together, I made an attempt to take it out. Tried hammering it out from the inside, tried taking a chisel and getting it from in-between the head and the base. Used a bunch of pb blaster. Nothing worked so I worked around it again. Well, went on a test run and everything worked except I'm leaking oil from the tensioner now. Seems like I broke the gasket in my attempts to get it out.
Im now at the point where I've taken the studs out and I can get it to spin a little if I take a hammer and metal rod and hit the tensioner where the holes are but nothing else seems to be working. Has anyone experienced something like this or does anyone have suggestions? I haven't tried heat yet but that seems to be my next step.
Cheers,
Pat
Cheers,
Pat
