Hello everyone!
I've been struggling for well over a year to get my 93 80 series to run. I'll save the drawn out process I had to eventually arrive at the point I'm at now, but in short the following items ended up being problems and required attention:
Which leads me to the current state. I have a rebuilt VAF that "works". It tests fine and I'm able to get the truck to idle smoothly and rev high. However, to get there I had to dig in to the VAF quite a bit and compare it to a faulty OEM. I found that the clock spring that runs the flapper, and potentiometer was quite a bit more tight than it should probably be. That was leading to the engine failing to fully move the flapper. Not enough vacuum. I backed off the spring and got full range of motion with vacuum. Then I discovered that there was adjustment available in the armature itself which significantly helped the idle.
I finally have this thing running, but all this VAF tuning has me concerned that I could be following a procedure to set them up correctly. All my tuning has been by ear. I know there's a procedure to adjust/tune the VAF bypass though it didn't seem to do much, if anything, for me. Does anyone have any information on these meters beyond the generic install/testing process?
Ultimately I'd like to remove and replace the VAF with a MAF, but the conversion modules for that seem to be rare and information isn't that great for my year.
Thank you for your attention. I feel like I'm pretty far offroad with this project!
- TPS
- IAC
- VAF
- EGR (eventually deleted)
- O2 sensors
- PAIR valve (eventually deleted)
- Vacuum leaks under the intake plenum
- Injector, TPS, and VAF plugs
- Fuel pressure regulator
- spark plugs
- Fuel pump relay
- Fuel pump
- Fuel filter
