For Sale 1997 Toyota Land Cruiser FZJ80 5.3LS camper conversion *PRICE DROP* $30K (1 Viewer)
Year
1997
  1. 80 Series
Mileage
289998
Color
Green
For sale is my 1997 Toyota Land Cruiser camper conversion with 5.3 Vortec and 4L60E transmission. This rig has been such a proven vehicle for me, it's been to Baja a few years ago and I've taken two longer trips this year in it, once to the Mojave Road in California and more recently to Moab, Utah. Please check out the description below and let me know if you have any questions. Built and located in Stevensville, Montana by myself. Would potentially entertain a PARTIAL trade for another 80 or 100 series cruiser. More information on my IG page @rigoverland.
1997 Toyota Land Cruiser 80 Series Camper
Drivetrain
2001 5.3 Vortec V8 engine swap (LS swap) 170k miles
  • All sensors and front mount accessories replaced with swap, new water pump, new oil pump, new timing chain and gears,new f body oil pan, new alternator, new AC pump.
  • AC fully functional
  • Mild tune done by ER Automotive
4L60E trans
NOVAK Conversions modified pan
Toyota HF2A(V) Factory T-case
  • Marks adapters trans/t-case adapter
  • 2wd/4wd conversion spool (lockout hubs)
Open Diffs, it does NOT have factory lockers
Chassis
  • 290K miles on chassis & body
  • OME 3” suspension lift with OME shocks, heavy coils in rear
  • Redhead Steering gearbox, new 4/24
  • ARB adjustable front panhard
  • Slee stainless extended brake lines
  • Delta VS rear panhard re-location bracket
  • Front axle full knuckles rebuilt, koyo bearings, gaskets, etc. All tie rod and drag link ends replaced with OEM Toyota parts, sandblasted and painted with chassis paint
  • Sway bar bushings and ends replaced
  • LC Phil sway bar disconnects
  • Front radius arms and upper control arm bushings replaced with Toyota OEM (lower radius bushings are OME)
  • AVM lockout hubs
  • Driveshaft universals have been replaced
  • Frame extension with custom spare tire mount, allows a full 35” tire, also allows the spare to be pulled farther up into the chassis with new style cable crank winch, mac’s y-strap for extra protection
Wheels & Tires
  • [Quantity 5] 17x9.5 Black Rhino Stadium wheels with custom machined hub bores
  • [Quantity 5] 315/70R17 BFG K02 All terrain tires
Interior
  • Front seats, center consol, rear cushion re-upholstered, re-foamed, all to match
  • New OEM heater core installed
  • All factory gauges are operational
Extras
  • ARB 8’ awning
  • ARB winch bumper (winch not included)
  • Radius fabrications stainless snorkel
  • Amber fog lights
  • I have both rear leather seats
Camper Exterior
  • Custom aluminum wedge style popup, LC body cut behind rear doors, camper built in place using insulated aluminum sandwich panels, aluminum sub frame and fabricated parts, 8’ tall x 17’ OAL
  • Water-resistant tent fabric on popup, 3 zipper windows with screens
  • Artic Tern Windows
  • Fabricated hatch style rear door with double acting dead bolt style lock, dual gas struts lift the door
  • Poli-all extruded PVC/aluminum hinges used for roof and rear door.
  • Roof is fully insulated, rear roof rack, provisions for a second roof mounted spare, versatie track system, 200w solar panel
  • Torlift scissor steps, easily removable when traveling
  • LED tail lights
  • I also have some aluminum mounts I made that will allow a pair of inflatable stand up paddle boards or other objects to be stored on the rear wall
Camper interior
  • Queen size memory foam mattress, bed platform hinges from the front so you can move around, stand at sink, etc.
  • Wood cabinets with butcher block top
  • Dometic sink with electric water pump
  • Dual (or more) interior jerry can storage
  • Shelf for basic camp style stove
  • Wayska cabin diesel heater with custom external fuel tank (aluminum)
  • Flush mount interior puck lights, 4 in the roof and 4 under the bed, controlled by two independent switches or remote
  • Victron energy solar controller, blue seas switch panel/fuse box, 200w solar panel, agm deep cycle house battery (independent of LC)
  • Iceco fridge
  • Bench opens for storage, also has a cubby for small cassette toilet or stair storage, etc.
  • I also have both rear seats that will be included
Known issues
  • Motor ticks when it’s cold, I've found a broken ex manifold bolt that will be replaced
  • Body has some rust in the rear lower ¼ panels under the rear doors, I have a welded in patch panels on the passenger side, I have the panel for the driver side I will include in the sale, there is also some other small spots, one on the lower driver door, the radiator core support has some spots (will include new core support as well)
  • Windshield is cracked
  • Passenger seat has a stripped motor gear
  • Rear main seal has a slight drip
  • Odometer seems to be intermittent lately
Awesome camping spot at those rocks! I camped there for two or three days, we did some climbing on the rock too, somebody put some anchors on it.
Oh ya, GLWS!
Cheers
The first picture with the awning out is camped on that beach, talk about a pristine Baja beach. It was our favorite spot down there. We paddled out before sunrise and found sea turtles floating on their backs sunbathing I would guess. It was incredible. Also saw a humpback cruising by later in the day.
Have you ever had any issues with water getting in your snorkel? Been considering a stainless snorkel. Beautiful rig, wish I could afford it...
Price drop to $38,500. Also, have fixed the rust issues on the cab corners and a few other spots. Have cut out and replaced with 80 series corners.
Price drop $32k, willing to consider a partial trade for lightweight short box cabover camper: six-pac, bigfoot 611, northern lite 610, etc.
call/text Ian @ 406-830-5266
