For Sale 1997 LX450 (Triple locked, 212,9xx miles)
Year
1997
  1. 80 Series
Mileage
212900
Color
White
Great condition 1997 Lexus LX450 with significant upgrades and extensive maintenance. In great running and operating condition. Highlights include: triple locked, 24 gallon auxiliary fuel tax (~49 gallons of capacity), ARB bumpers front and rear, 4 inch lift, SLEE rock sliders, very nice interior condition, OZ-USA spot/flood combo lights, new brakes, new AC, PHH fix, D light works, rear camera, winch. Lockers exercised every few months. I've owned this since 2020 and it was my daily driver in Houston for about 3 years.
Price: $33,000
Issues: throws a PO401 code occasionally (haven't addressed the EGR yet), passenger side mirror need to be replaced (it moves up/down but not right/left), I recently noticed a small rust issue developing around the windshield, passenger side (see pic).
I kept a running list of things done to the truck. Some of the items at the top (suspension, ARB front and rear bumpers, rock sliders) were installed prior to my purchase. I have many of the receipts prior to my purchase and all of them since 2020.
  • SLEE - 4" Front Coil Spring - Medium - PAIR
  • SLEE - 4" Rear Coil Spring - Medium - 80 Series Land Cruiser - PAIR SLEE - [4" Lift] - Remote Reservoir Shock. Front.
  • 10.8" Stroke, 15.2" Com, 26" Ext. 14MM fixed pin top and bottom.
  • LH and RH Bracket and 4 Hose Clamps (2.75").
  • OME Steering Stabilizer SLEE - [4" Lift] - Piggyback Reservoir Shock. Rear.
  • 10.8" Stroke, 15.67" Com, 26.5" Ext. 14mm Fixed pin top, eyelet bottom.
  • SLEE - Billet Front Control Arms - - 6" Lift - Coated, no bushings - PAIR Bushing - Control Arm - Front Axle
  • Bushing - Front - Lower Control Arm - Frame Side - 80 Series
  • SLEE - Rear Swaybar Drop Brackets - PAIR
  • SLEE - 2" Front Swaybar Drop Blocks - PAIR
  • SLEE - 2" Rear Bumpstop Drop Blocks - PAIR
  • SLEE - 2" Front Bumpstop Drop Pucks -- PAIR
  • SLEE - Front Adjustable Panhard Rod - Complete unit with new bushings. LHD
  • SLEE - Rear Panhard Rod - Adjustable -
  • ARB Adjustable Upper Control Arms -
  • SLEE - Front Double Cardan Shaft - Reconditioned hard parts with all new moving parts.
  • Brake Line Kit - Stainless - '93-'97 Land Cruiser (3 pc frame to axle kit)
  • Breather Extension Kit
  • Emergency Cable Bracket Spacer
  • KIT * SOF 4" Premium Lift Kit for 80 Series Land Cruiser
  • Exhaust (2020)
  • o2 sensors (2020)
  • 24 gal aux fuel tank
  • 33" tires (2020, approximately 30k miles)
  • New head unit
  • Rear camera
  • Tailgate storage system
  • Rear storage box in rear. Removable.
  • New light fixtures all around (Depo headlights, taillights, turn signals, corner lights)
  • LED interior lights
  • LED lights on rear hatch with switch
  • New wiper linkage and motor
  • Steering shaft seal at floorboard,
  • Spot/flood combo light on the arb bar: 80w High Ouput DRL 7" Round OZ-USA® LED Light Combo Spot + Flood Beam with DRL Function
  • Separate switches in cab for DRL and Floods
  • Right rear door lock actuator,
  • 2 new window motors,
  • New antenna and motor, manual instead of auto Loud gear grinding noise after power antenna lowers. - https://forum.ih8mud.com/threads/loud-gear-grinding-noise-after-power-antenna-lowers.1187884/page-2
  • Knuckle rebuild
  • Wheel bearings
  • Distributor seal
  • Lower pan seal
  • Trailer 4 pin rewire
  • Hood hatch struts
  • PHH
  • Temp sensor
  • Alternator
  • Recent brakes, front and rear
  • Parking brake fix
  • Rear hatch struts
  • New fan and fan clutch
  • New air vents
  • OME SD24 Steering Stabilizer
  • D light fixed
