Parting Out 1996 FZJ80/LX450--NEW PARTS! (1 Viewer)
Do you still have this?
Rear seat step plates $10 each
MAJOR UPDATE 4/26/18--New list of parts and prices!
Located in Western Nebraska—only about 2.5 hrs from Denver. Willing to ship USPS, UPS, or palletize and ship via freight.
Parts list with prices below. It is not complete so if I don’t have it listed just ask! Everything is OBO. I just took a stab at prices so if you disagree make an offer. I’m not trying to get rich or make a big profit, I’m just trying to be fair and reasonable. If you buy multiple things I will discount the prices!
Feel free to PM or email bmschmitt at gmail.com.
EXTERIOR PARTS
DS Tail light (has paint overspray from PO) $15
Rear marker lights (pair) $15
PS side mirror $50
LED lights (Kawell 48W floods with bar mounts, x5) $50
Front flare to running board extensions (DS only) $10
Front bumper corners (pair) $100
Rear bumper corners (pair) $75
LX450 fender flares (each) $50 each
LX450 door cladding (DS rear door) $40 each
Tow hooks $10 each
Front doors (shell+window) $100 each
Front fender (DS) $100 each
Rear hatch glass $50
Windshield wiper motor $30
Windshield wiper linkage $25
Windshield wiper reservoir w/ pump $40
PS front window motor $40
PS rear window motor $15
PS rear door quarter window $5
DS rear door quarter window $5
PS rear door handle $15
DS rear door handle $15
Hood struts (pair) $25 pair
Wiper sprayers $5 each
Cowl $50
Cowl opening grates (set) $10 set
Front bumper vent inserts (pair) $10 pair
Hood hinge (pair) $20 pair
Fuel filler door $15
Sunroof control relay (85921-60011) $50
Sunroof motor (85730-60011) $50
Rear wiper motor $20
Head lights (pair) $200
Corner lights (pair) $30
DS Front turn signal $15
PS Front turn signal $15
PS Tail light $30
DS side mirror $50
LX450 rear mud flaps (pair) $50
Grille $40
Rubber fender liners (DS) $10
Rubber fender liners (PS) $10
Third brake light $40
DS Rear door window $30
PS Rear door window $30
Valence $40
Hood latch $10
Hood cable $10
Hood insulator/liner $50
Sunroof assembly $200
Door limiters $5 each
Tailgate latch plates $10 pair
Hatch struts $25 pair
Door belt moldings (full set) $80
LX450 door cladding (PS rear door) $40
INTERIOR PARTS
Grab handles (roof) $5 each
Grab handles (B-pillar) $5 each
PS Front seat belt $20
PS Middle seat belt $20
DS 3rd row seat belt $10
Map light/sunroof control $10
Dome lights $20
Steering wheel airbag $40
Glove box door $20
Rear view mirror $20
Power antenna switch $10
Defrost switch $5
Turn signal/washer/headlight switch/clock spring $60
Dash dimmer switch $10
Power/2nd switch $10
Head unit (Kenwood KDC-BT21) $30
Dash pad $200
PS airbag cover $50
PS airbag cover $40
PS side mirror cover $5
DS front sill plate $10
PS front sill plate $10
DS rear sill plate $5
Cargo area sill plate $5
Cargo side panel (DS, missing door) $20
Cargo side panel (PS, with door) $30
Rear hatch panel $10
Sunroof trim interior moulding weatherstrip $10
Door trim interior moulding weatherstrip $10
B-pillar lower panel (DS) $10
B-pillar lower panel (PS) $10
C-pillar lower panel (DS) $5
C-pillar lower panel (PS) $5
Kick panel (DS) $10
Kick panel (PS) $10
Gauge panel surround $10
Radio/AC bezel $35
Middle dash panel (DS) $35
Lower dash panel (DS) $35
Arm rest pads (all 4 doors available) $5 each
A-pillar upper panel (DS) $10
A-pillar upper panel (PS) $10
B-pillar upper panel (DS) $10
B-pillar upper panel (PS) $10
D-pillar upper panel (DS) $10
D-pillar upper panel (PS) $10
AC amplifier (Denso 077800-0111) $35
Heat servo motor (Denso 063700-2710) $10
Heat servo motor (Denso 063700-2681) $15
Heater AMP module (87161-60020) $25
Air bag sensor assembly (89170-60010) $75
Air amplifier assembly (88650-60081) $35
Interior lamp control relay (85965-60010) $25
Headlamp retainer relay (85961-30050) $15
Seatbelt warning relay (85991-16050) $25
Stereo amplifier (86280-60100) $10
Antenna relay (85914-60040) $50
Horn relay (90987-01003) $5
Flasher (81980-12070) $15
Blower relay (90987-04002) $5
Headlight Relay (90987-02006) $5
Transfer case shifter boot $10
Hatch interior door handle and surround $15
Ash tray $20
Cigarette lighter $5
Clock/center dash vent assembly $35
1996 LX450 Owner's manual $10
Gauge cluster $50
Front seats (pair) $150
Middle seats (pair) $150
Front console (gear shift) $40
Center console lid with armrest $40
Grab handles (A-pillar) $5 each
BH3D double cup holder $40
DS Front seat belt $40
PS 3rd row seat belt $10
Sun visors (pair) $125
Steering wheel (less airbag) $50
Steering column cover (clamshell) $20
Aux. light switch $20
Hazard switch $10
Rear heater switch $5
Mirror control switch $10
Rear PS door lock solenoid $5
Rear DS door lock solenoid $5
Front DS door lock solenoid $5
Front PS door lock solenoid $5
Hatch lock solenoid $5
CB radio (Uniden 510XL) $20
Tool set (mostly complete) $75
Window power switches w/ wood surround $5
Climate controls $50
AC amplifier (88650-60210) $185
Factory jack $10
Cabela’s Trail Gear Seat covers (front buckets, rear bench) $40
Door control relay unit $40
Front DS window motor $40
Rear DS window motor $15
Shifter handle $20
Fuse panel cover $15
DS side mirror cover $5
PS rear sill plate $10
Headliner $100
RS3000 w/ 2 fobs $105
Cargo/jack panel cover $15
DS dash vent $25
DRIVETRAIN PARTS
AC lines (all available)
AC condensor coil $150
Coolant overflow tank $10
Water pump pulley $20
Flex plate $40
Alternator $40
PS reservoir $10
Transfer case $200
Exhaust downpipe with front catalytic converter (cat likely bad) $100
Rear catalytic converter (cat likely bad) $25
Muffler and adjacent pipes $25
Tailpipe $40
Intake manifold (upper and lower) $75
Front driveshaft $75
Rear driveshaft $50
Air intake tube $25
Radiator $85
Mass airflow sensor (MAF) (22250-66050) $50
Radiator fan shroud $35
Radiator fan $20
Throttle body $50
EFI Relay (90987-02004) $5
Taillight/Horn Relay (90987-01003) $5
Ignition coil (19080-66010, 90919-02209) $10
Coil igniter (89621-26010) $35
ABS relay (88263-12080) $15
ABS computer (89541-60020, 89540-60040) $15
Cruise control actuator/cable/cover (88002-60030) $125
Cruise control computer (88240-60060) $100
Transmission relay (89531-60010) $50
Computer shift lock control (85933-60050) $5
Fuel pump relay (28381-16020, 28380-66010) $25
Complete locking axle assemblies (with locker ECU and dash switch) $1,500
LX450 wheels with 315/75-16 Firestone Destination ATs (5,000 miles, set of 5, no center caps) $800
Lexus wheel center caps $20 each
AC compressor $100
Transmission $165
Spark plug wires (NGK, 5,000 miles) $40
Distributor w/ new cap $75
Exhaust manifold (front and rear) $50
Brake MC/booster $100
Steering box $150
Starter (5,000 miles, Napa) $75
Air cleaner $30
ECU $100
CHASSIS/SUSPENSION PARTS
Transfer case skid plate $10
Front sway bar $20
Rear sway bar $20
Front panhard rod $20
Rear panhard rod $20
Lift springs (OME 2.5") $240
Front control arms $50 pair
Rear upper control arms $20 pair
Rear lower control arms $20 pair
Drag link $50
Tie rod $50
I need the power antenna, clock spring and fan clutch.
Hello, looking for all 4 fender flares, ignition switch, transfer case skid plate, Coolant overflow tank, Tow hooks, Driver side mirror
Thx
Looking for the ABS wiring harness for the front right. Wiring harness from the connector in the middle of the front axle to the connector on the front right wheel sensor. Pretty sure my sensor is good and it is just that short wire run I need if you have it.
Hi. Are you still parting out? If so and your driver's side interior fuse assembly is in good shape, I'm interested. Thanks.
EXTERIOR PARTS
PS side mirror $50
Tow hooks $10 each
Cowl $50
PS Tail light $30
DS side mirror $50
Grille $40
Valence $40
Hood latch $10
Hood cable $10
INTERIOR PARTS
Dome lights $20
Glove box door $20
Defrost switch $5
Dash pad $200
PS airbag cover $50
PS airbag cover $40
Kick panel (DS) $10
Kick panel (PS) $10
Radio/AC bezel $35
Ash tray $20
Gauge cluster $50
Hazard switch $10
Factory jack $10
Shifter handle $20
Headliner $100
DS dash vent $25
DRIVETRAIN PARTS
Flex plate $40
Alternator $40
PS reservoir $10
Transfer case $200
Tailpipe $40
Rear driveshaft $50
Air intake tube $25
Radiator $85
Radiator fan $20
Throttle body $50
AC compressor $100
Transmission $165
Steering box $150
Air cleaner $30
ECU $100
Front sway bar $20
Rear sway bar $20
Drag link $50
Tie rod $50
Front door panels
Looking for a LX450 center console lid complete with hinges in good condition… I will recover so the leather is no big deal. PM me if you can
help.
Sharky
Looks like he hasn't been on the forum since June 2021??
THE SELLER OF THESE PARTS APPEARS TO HAVE NOT BEEN ON THE FORUM SINCE JUNE OF 2021
FWIW
