Parting Out 1996 FZJ80/LX450--NEW PARTS!
Western Nebraska
MAJOR UPDATE 4/26/18--New list of parts and prices!
Located in Western Nebraska—only about 2.5 hrs from Denver. Willing to ship USPS, UPS, or palletize and ship via freight.
Parts list with prices below. It is not complete so if I don’t have it listed just ask! Everything is OBO. I just took a stab at prices so if you disagree make an offer. I’m not trying to get rich or make a big profit, I’m just trying to be fair and reasonable. If you buy multiple things I will discount the prices!
Feel free to PM or email bmschmitt at gmail.com.
EXTERIOR PARTS
DS Tail light (has paint overspray from PO) $15
Rear marker lights (pair) $15
PS side mirror $50
LED lights (Kawell 48W floods with bar mounts, x5) $50
Front flare to running board extensions (DS only) $10
Front bumper corners (pair) $100
Rear bumper corners (pair) $75
LX450 fender flares (each) $50 each
LX450 door cladding (DS rear door) $40 each
Tow hooks $10 each
Front doors (shell+window) $100 each
Front fender (DS) $100 each
Rear hatch glass $50
Windshield wiper motor $30
Windshield wiper linkage $25
Windshield wiper reservoir w/ pump $40
PS front window motor $40
PS rear window motor $15
PS rear door quarter window $5
DS rear door quarter window $5
PS rear door handle $15
DS rear door handle $15
Hood struts (pair) $25 pair
Wiper sprayers $5 each
Cowl $50
Cowl opening grates (set) $10 set
Front bumper vent inserts (pair) $10 pair
Hood hinge (pair) $20 pair
Fuel filler door $15
Sunroof control relay (85921-60011) $50
Sunroof motor (85730-60011) $50
Rear wiper motor $20
Head lights (pair) $200
Corner lights (pair) $30
DS Front turn signal $15
PS Front turn signal $15
PS Tail light $30
DS side mirror $50
LX450 rear mud flaps (pair) $50
Grille $40
Rubber fender liners (DS) $10
Rubber fender liners (PS) $10
Third brake light $40
DS Rear door window $30
PS Rear door window $30
Valence $40
Hood latch $10
Hood cable $10
Hood insulator/liner $50
Sunroof assembly $200
Door limiters $5 each
Tailgate latch plates $10 pair
Hatch struts $25 pair
Door belt moldings (full set) $80
LX450 door cladding (PS rear door) $40
INTERIOR PARTS
Grab handles (roof) $5 each
Grab handles (B-pillar) $5 each
PS Front seat belt $20
PS Middle seat belt $20
DS 3rd row seat belt $10
Map light/sunroof control $10
Dome lights $20
Steering wheel airbag $40
Glove box door $20
Rear view mirror $20
Power antenna switch $10
Defrost switch $5
Turn signal/washer/headlight switch/clock spring $60
Dash dimmer switch $10
Power/2nd switch $10
Head unit (Kenwood KDC-BT21) $30
Dash pad $200
PS airbag cover $50
PS airbag cover $40
PS side mirror cover $5
DS front sill plate $10
PS front sill plate $10
DS rear sill plate $5
Cargo area sill plate $5
Cargo side panel (DS, missing door) $20
Cargo side panel (PS, with door) $30
Rear hatch panel $10
Sunroof trim interior moulding weatherstrip $10
Door trim interior moulding weatherstrip $10
B-pillar lower panel (DS) $10
B-pillar lower panel (PS) $10
C-pillar lower panel (DS) $5
C-pillar lower panel (PS) $5
Kick panel (DS) $10
Kick panel (PS) $10
Gauge panel surround $10
Radio/AC bezel $35
Middle dash panel (DS) $35
Lower dash panel (DS) $35
Arm rest pads (all 4 doors available) $5 each
Rear seat step plates $10 each
A-pillar upper panel (DS) $10
A-pillar upper panel (PS) $10
B-pillar upper panel (DS) $10
B-pillar upper panel (PS) $10
D-pillar upper panel (DS) $10
D-pillar upper panel (PS) $10
AC amplifier (Denso 077800-0111) $35
Heat servo motor (Denso 063700-2710) $10
Heat servo motor (Denso 063700-2681) $15
Heater AMP module (87161-60020) $25
Air bag sensor assembly (89170-60010) $75
Air amplifier assembly (88650-60081) $35
Interior lamp control relay (85965-60010) $25
Headlamp retainer relay (85961-30050) $15
Seatbelt warning relay (85991-16050) $25
Stereo amplifier (86280-60100) $10
Antenna relay (85914-60040) $50
Horn relay (90987-01003) $5
Flasher (81980-12070) $15
Blower relay (90987-04002) $5
Headlight Relay (90987-02006) $5
Transfer case shifter boot $10
Hatch interior door handle and surround $15
Ash tray $20
Cigarette lighter $5
Clock/center dash vent assembly $35
1996 LX450 Owner's manual $10
Gauge cluster $50
Front seats (pair) $150
Middle seats (pair) $150
Front console (gear shift) $40
Center console lid with armrest $40
Grab handles (A-pillar) $5 each
BH3D double cup holder $40
DS Front seat belt $40
PS 3rd row seat belt $10
Sun visors (pair) $125
Steering wheel (less airbag) $50
Steering column cover (clamshell) $20
Aux. light switch $20
Hazard switch $10
Rear heater switch $5
Mirror control switch $10
Rear PS door lock solenoid $5
Rear DS door lock solenoid $5
Front DS door lock solenoid $5
Front PS door lock solenoid $5
Hatch lock solenoid $5
CB radio (Uniden 510XL) $20
Tool set (mostly complete) $75
Window power switches w/ wood surround $5
Climate controls $50
AC amplifier (88650-60210) $185
Factory jack $10
Cabela’s Trail Gear Seat covers (front buckets, rear bench) $40
Door control relay unit $40
Front DS window motor $40
Rear DS window motor $15
Shifter handle $20
Fuse panel cover $15
DS side mirror cover $5
PS rear sill plate $10
Headliner $100
RS3000 w/ 2 fobs $105
Cargo/jack panel cover $15
DS dash vent $25
DRIVETRAIN PARTS
AC lines (all available)
AC condensor coil $150
Coolant overflow tank $10
Water pump pulley $20
Flex plate $40
Alternator $40
PS reservoir $10
Transfer case $200
Exhaust downpipe with front catalytic converter (cat likely bad) $100
Rear catalytic converter (cat likely bad) $25
Muffler and adjacent pipes $25
Tailpipe $40
Intake manifold (upper and lower) $75
Front driveshaft $75
Rear driveshaft $50
Air intake tube $25
Radiator $85
Mass airflow sensor (MAF) (22250-66050) $50
Radiator fan shroud $35
Radiator fan $20
Throttle body $50
EFI Relay (90987-02004) $5
Taillight/Horn Relay (90987-01003) $5
Ignition coil (19080-66010, 90919-02209) $10
Coil igniter (89621-26010) $35
ABS relay (88263-12080) $15
ABS computer (89541-60020, 89540-60040) $15
Cruise control actuator/cable/cover (88002-60030) $125
Cruise control computer (88240-60060) $100
Transmission relay (89531-60010) $50
Computer shift lock control (85933-60050) $5
Fuel pump relay (28381-16020, 28380-66010) $25
Complete locking axle assemblies (with locker ECU and dash switch) $1,500
LX450 wheels with 315/75-16 Firestone Destination ATs (5,000 miles, set of 5, no center caps) $800
Lexus wheel center caps $20 each
AC compressor $100
Transmission $165
Spark plug wires (NGK, 5,000 miles) $40
Distributor w/ new cap $75
Exhaust manifold (front and rear) $50
Brake MC/booster $100
Steering box $150
Starter (5,000 miles, Napa) $75
Air cleaner $30
ECU $100
CHASSIS/SUSPENSION PARTS
Transfer case skid plate $10
Front sway bar $20
Rear sway bar $20
Front panhard rod $20
Rear panhard rod $20
Lift springs (OME 2.5") $240
Front control arms $50 pair
Rear upper control arms $20 pair
Rear lower control arms $20 pair
Drag link $50
Tie rod $50
Willing to sell the rear diff separate of the axle? Also interested in the front locker switch with a section of pigtail.
For now I’m going to keep the lockers as a complete set to accommodate a swap into a non-locked truck. The set would include complete front and rear axles (hub to hub), locker switch, and locker ECU.
Makes the most sense. I'm looking to swap into a 60 axle. Let me know if the situation changes but I'm sure you'll get someone interested in the full set.
Which OME lift does it have on it?
Does the A/C work?? I am in need of a compressor... if it’s good, what’s your asking price??
2.5”, but I am not sure if they are medium or heavy. I can take some hub to fender measurements if that would help. The LX doesn’t have any weight or heavy accessories over stock.
If we can ID the lift I’d be interested in it. I’m looking for a J lift. I’m assuming it’s springs shocks and damper. If the price is right shipped to 93230.
Are the rear door interior panel in good shape? Interested in both left and right sides. Houston, TX 77064. Thanks
PM sent
They’re in good shape but the factory speaker grilles have been removed. Let me know what you think. I’m figuring $40 each + shipping.
Would you be able to post pictures of the dash board and climate control module? If they're in decent shape, I'm interested in both.
Dash pad is in great shape. No cracks. $200+shipping.
Climate controls are good except the faux wood is peeling a bit. $50+shipping.
If you’re interested let me know your zip and I will get you a shipping quote.
No real luck on identifying the lift. Previous owner just says OME 2.5”.
Measurements from center of wheel to fender flare are as follows:
Front Drivers: 21.5”
Front Passenger: 22.25”
Rear Drivers: 22.25”
Rear Passenger: 23”
No real weight in the truck except 35” spare tire/wheel in the cargo area.
Shocks are ugly but I never got any seat time to tell if they are any good. Steering damper is old OEM.
I am thinking $250+shipping for the springs... is that reasonable?
How much for the carpet and all 3 Rows of Seats? I am in Denver so not terribly far.
Carpet looks to be in decent shape but could use a good cleaning. I have a guy local to me that says he wants the front seats but he hasn’t paid yet. DS front seat works perfectly. PS front seat front/rear control works but gets jammed so may have a gear stripped. All other functions of PS front seat work. Second row seats look good but again, could use a little cleanup. Third row seats are missing.
Front row seats: $175 (if local guy doesn’t take them)
Second row seats: $150
Carpet (full set of front, center, cargo, wheel wells, tailgate): $300
Shipping would be in addition to the prices above or since you’re close we could meet in Brush or Ft. Morgan to avoid shipping costs.
Front driver side seat belt shipped to 53214? Also the third row rear passenger side seat belt?
