1996 Factory stereo tech question
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
I have a 1996 FZJ80 and would like to upgrade my factory sound system. I have been told that my 80 has an amp. What I need to know is that true? Where can I pick up the preamp output from the factory deck? I would like to keep factory head unit to create a sleeper system. No Bling in the dash. I know the factory deck is not the best for what I want to do, but my plans are to move up to XM thru an Fm mod. So all am looking for is a flat preamp output signal. I will make all sound adjustments via crossovers and amp gain settings.
Phil
yours is a Toyota not a lexus right?
Donno the answer to your question, but if the system is anything like the LX, you might want to scarf a copy of the factory wiring diagram with the color codes. It's got more wires than anything I've ever F'd with.
:beer:
Rookie2
Phil, the loom going from the head unit to the amp located to the right of the glovebox should be low power. It would be a good spot to tap in a line to RCA converter.
