- Year
- 1995
- Vehicle Model
- 80 Series
1995 Toyota Land Cruiser FZJ80
Currently has 232,768
I have owned this vehicle since January of 2015. When I took ownership it was bone stock. I don’t know much of its history before I had it. Its completely 100% rust free except for a thumbnail size of bubbling dead center top of the windshield. I live in Bend, Oregon (desert) and this spot has not grown or gotten any worse. I have never found a single stuck bolt in all the modification I have done to this rig. The other thing I don’t know is if the Head Gasket has ever been done. I have sent away oil samples to Blackstone Labratory and also tested the block and everything has come back negative.
This rig was built to be used. This isn’t an “overland” build that was made to take the kids to the supermarket (although it does that also). It has been used for what it was built for and because of that there area couple blemishes. However, it has been very well taken care of, upgraded, and preventative maintenance is always done ahead of
something breaking! I have kept a lot of receipts but not all of them and I have always kept a list of upgrades and major maintenance when it was done.
I wouldn’t hesitate to drive this across country tomorrow or even further. Its been a fantastic vehicle and its time for someone else to
enjoy it. I will try and list the things I can think of that aren’t working or need attention. But overall its a clean well built rig.
- CEL is on because of the P0401 code. I chased this back in 2015 for
a while with a new pcv valve, throttle body gasket, cleaned the
throttle body, new ear vacuum modulator, new pcv #1 and #2 hoses, and
new charcoal canister. It went away for a while and then came back. We
don’t have emissions here in Bend so I didn’t pursue it further.
- It doesn’t have the wiper fluid bottle installed. When I installed
the dual batteries I had to move the fluid canister and I haven’t
reinstalled another one.
- Driver seat is torn like most 80s
- Power antenna doesn’t work any longer. I bought another one and tore
the thing out just to find out it was the antenna for a 97 not a 95
(teeth vs smooth).
- There are a few dents. I have tried to get pics of them. one in the
rocker, one in the driver side door/front clip, and one by the
passenger side tail light.
- A little spot of bed liner has chipped off on the driver side rear
fender well.
-Driver side front shock has a dent in the dust shield. It has not and does not affect the shock.
4/01/15 - New Antenna
4/08/15 - 6” Complete Slee Lift Lift 216,000
4/08/15 - F&R Iron Man Shocks
4/08/15 - Slee DC front shaft
4/15/15 - 4x4 Labs Rear Bumper
4/18/15 - 4x4 Labs Front Bumper
4/27/15 - Installed AC Dryer in battery trey with custom made AC hose/line
8/01/15 PHH
8/01/15 FHH
8/01/15 Full Coolant flush (block and radiator)
8/01/15 3 new radiator hoses with constant torque clamps
8/01/15 new o-ring on dizzy
8/01/15 new heater valve
8/01/15 advanced timing to 7
8/01/15 New AC Controller
8/01/15 New AC Relay
8/01/15 New Air intake tube
11/3/15 2 New Exhaust hangers
12/1/15 Deflared, fiberglass holes, sprayed Raptor Liner
12/9/15 New valve cover gasket
12/9/15 New PCV Valve and Grommet
12/9/15 New Throttle body gasket
12/9/15 Cleaned throttle body
12/9/15 New EGR Vacuum Modulator
12/9/15 New PCV #1 and #2 hoses
12/9/15 New #2 water bypass hose
12/9/15 (6) New Spark plug tube gaskets
12/9/15 Painted valve cover with Engine Enamel Blue
12/11/15 New Hood Struts
03/23/16 ARB Lockers Front and Rear
03/23/16 Nitro 5.29 gears
03/23/16 ARB CKMA 12 Compressor
05/01/16 Engo 12k lb winch
05/03/16 Rear rotors turned
05/09/16 New Ujoints in rear driveshaft
05/09/16 CB install with external speaker and Firestik
06/16/16 Intall ARB on board air
10/19/16 Rebuilt Starter (New OEM contacts and Plunger)
03/15/17 New Rear Pinion Bearing
03/17/17 New Charcoal Canister
04/05/17 Straightened and Balanced rear Drive Shaft
04/05/17 New Ujoints Rear Driveshaft
04/05/17 New rear pinion Seal
04/05/17 New Power Steering Hose
05/01/17 ABS Delete, LSPV Delete
05/02/17 Sealed exhaust between cats
12/28/17 Full Knuckle rebuild w/ Marlin inner axle seals
12/28/17 New Calipers
12/28/17 Front rotors turned
12/28/17 New front brake pads
12/28/17 New tie rod ends
1/05/18 Sylvania Ultra Low Beams
1/05/18 AuxBeam High Beams
1/08/18 Dual Batteries
1/08/18 Rocker switch panel, dual volt meter, & USB outlets
1/08/18 Blue Sea fuse blocks with built in ground under hood and in rear panel
10/20/18 Straighten and balance front drive shaft
11/22/18 Installed rock lights
12/8/18 Installed AuxBeam rear pods
12/15/18 Installed rear interior lights with dimmer switch
1/3/19 Sony Head Unit with Apple Car Play
1/5/19 Depot rear LED tail light housing with LEDs
4/30/19 New Deep Cycle Battery
5/1/19 Shaky Mirror fix
5/2/19 New Muffler and gasket between cats
7/18/19 New Front Main Seal
7/18/19 New oil pump seal
7/18/19 Resealed oil pan
7/18/19 New Distributor rotor, cap, and seal
7/18/19 New OEM Spark Plugs
7/18/19 New Plug Wire Assembly
7/18/19 New Radiator
7/18/19 New AC Condensor
7/18/19 New AC Compressor
7/18/19 New Receiver Dryer
7/18/19 New Idler Pulley
7/18/19 Full Coolant flush
7/18/19 New Thermostat and gasket
The truck is located in Bend, Oregon. I am asking$16,000 $13,000 obo (make offer). I would consider a partial trade for a built Toyota pickup (no single cabs, no bobbed beds) or a first gen Tundra. Besides that, cash only. RTT not included. Please let me know if you have any questions.
(teeth vs smooth).
fender well.
8/01/15 PHH
8/01/15 FHH
