- Thread starter
- #41
Yes it is lol
Is that a real CSL in the background?
Underdog Racing Development
This is if u want to run a piggyback with 6 additional injectors that kick in during boost. May be easier to just go stand alone though at that pricepoint.
Most people are running single turbos on the 5vz. A 3vzfe crankshaft is a direct drop in a 5vz and is a forged crank. Usually can find for 200 bucks used. Not to be confused with a 3vze motor which has a cast crank but would also drop in. Cx racing has a cheap turbo kit with manifolds for the 5vz tacomas. Some just use the cx turbo manifolds. Treadstone performance makes a kit for the 5vz to weld your own manifold.
Cool. Well like I said treadstone makes cylinder head exhaust manifold flanges for the 5vz which may cut down fab work for u.Thanks. I will most likely run a haltech or motec standalone on the truck and make my own manifolds and turbo kit. I do not mind secondary injectors but it is much easier for me to tune with big primaries only and run sequential so I can tune by cylinder. On my turbo setups I run a egt probe in each cylinder and run an aircraft controller to toggle through each cylinder and see where it is at. You would be amazed the difference in airflow to each cylinder with even a well designed intake manifold
