- Vehicle Model
- 80 Series
Hey guys,
I am parting out my 1HDT that has 300k km on it, recently started losing coolant. The engine did not overheat and it only drove about 150-200 mi losing coolant but never got hot, so I checked the compression and 1-5 were 470 + PSI but cylinder 6 had none. I pulled the head and discovered a blown gasket and a few cracks in 3 pistons as well as 3 very small cracks starting in the head between the valves
Please text me at 208-906-2411 and i'll get you more pictures and prices. I am open to offers.
INJECTOR PUMP - SOLD
INJECTORS - SOLD
G-TURBO GREEN WHEEL (10K MILES) - SOLD
TERRAIN TAMER 120A ALTERNATOR (10K MI ) - SOLD
BLOCK - SOLD
EXHAUST MANIFOLD - SOLD
24V STARTER ( REBUILT) - $300
CROSSOVER PIPE - $150
INTAKE MANIFOLD - $150
TERRAIN TAMER CRANK/AC PULLEY - SOLD
OEM AIRBOX - $150
VALVE COVER - SOLD
VACUUM PUMP - $225
POWERSTEERING RES - SOLD
CAMSHAFT - SOLD
CRANKSHAFT - SOLD
POWER STEERING WITH REBUILD KIT - $200
OIL COOLER - $150
OIL COOLER COVER - $50
FAN - $40
CLUTCH - $50
INJECTOR LINES ( ALL NEW) - SOLD
LEAKAGE PIPE - $40
TIMING COVER PLATES - SOLD
OEM DRIVESHAFTS - $150
AUTO FLYWHEEL - $300
AC COMPRESSOR - PENDING
I am probably missing a whole bunch but below are some pictures.
INJECTORS - SOLD
BLOCK - SOLD
OEM AIRBOX - $150
VALVE COVER - SOLD
VACUUM PUMP - $225
CAMSHAFT - SOLD
CRANKSHAFT - SOLD
OIL COOLER - $150
FAN - $40
CLUTCH - $50
LEAKAGE PIPE - $40
