One more thing, if you're converting to R134a from R12, you'll need PAG 46 oil, 7 ounces. Also, use an aftermarket drier, the Denso drier is not compatible with R134a.
Im installin all new stuff...not sure if that a conversion. Rock Auto has GPD, Four Seasons and AcDelco...? Whats best?One more thing, if you're converting to R134a from R12, you'll need PAG 46 oil, 7 ounces. Also, use an aftermarket drier, the Denso drier is not compatible with R134a.
Im guessing he will use whatever i source. Which would you suggest?Any of those 3 are ok. Is your mechanic using R12 which is the refrigerant that it originally came with, however, it's harder to get and more expensive than the newer refrigerant R134a. R12 uses A/C specific mineral oil. R134a uses PAG 46 oil and you have to use the oil that matches the refrigerant you're using.
woaoaoaoaoao R12 aint cheap...even on CLs lolololIf it was mine, I’d source some R12 off Craigslist and keep it R12. The good news is that the’60’s work well converted to R134a.
What all did it entail to swap to R134a? If im replacing the Compressor,Condensor and Evaporator...is it really a."swap". Wldnt it be just starting with R134a? Thanks. Fortunately...i spend moat my time between 7000'-9600' elevaton...dnt really need A/C....but i have dreams of a road trip to Panama innthe works WILL need A/C!Bingo - exactly why I converted to R134A. Much less expensive. Make sure to put a new Expansion Valve in there also. Good luck! I've been cruising all over with ice cold A/C after making the swap last week. These trucks are like heated greenhouses on wheels in the summer sun - it was brutal, so I was pretty darn motivated to get the A/C working
I'm glad it hasn't created a problem and maybe it's not a big deal, but Toyota shows drier 88471-12080 for R134a retrofit and 88470-14010 for R12 applications.
This thread re-hashes the debate on drier compatibility.
I haven't heard that but all of the aftermarket manufacturers I know of use desiccant that's compatible with both. Driers used to have a sticker on them that identified what desiccant was inside.Ah, interesting - I didn't catch that. I'm sure I used the 14010 Dryer as I didn't know about the retrofit TSB then... Maybe that accounts for the loss of refrigerant?
Is it true that any of the Dryer/Receivers that are painted BLACK are R134a compatible?
