For Sale 1987 3B Parts, Edic, Injection pump, intake,new glow plugs & Injectors, TURBO KIT FOR 3B
Letsgomoreplaces
Gear & Axle parts for ALL Toyotas new or old...
Washington
Website
www.letsgomoreplaces.com
Doing a 13bt Swap on a 1987 BJ73 24v
The 3B is bad internally but all accessories were working great:
-Glow plugs 19850-68060, nearly brand new $100 set of 4
-Injection Pump, has new venturi diaphragm & custom braided venturi lines, New Primer pump $600
-Edic Motor / Assembly works perfectly $225
-Freshly Rebuilt Injectors, set of 4 $375
-Used injectors, working set of 4 $150
-Intake manifold, throttle body $150
-valve cover $50
-misc brackets etc.
-Thermostat housing with nearly new Thermostat (cooler temp) $50
-Jefferson State Machining Turbo kit, 13bt
The turbo kit will be complete. The Jefferson Machining kit was not complete and I added all the things that would otherwise cause you delay at install-Turbo Kit with Garret Turbo
-Oil Feed and Return line with adapters-Silicone intake ant throttle body connections-Stainless intake tube-13bt Exhaust manifold, pre-tapped for Pyrometer probe-Custom down pipe piece so you can get the unit installed, and be able to drive it to the exhaust shop
$2k
Email inquiries are best carl@justdifferentials.com please include your postal code.
Email sent,
oil cooler and oil filter mount available?
