crushers
post ho
not a problem...
cheers
cheers
kiwiwonder said:I would like to put in the stock fan with a modified shroud but the stock fan blades go past the side of the radiator and make a fan shroud prety much imposible to fit with a stock fan. QUOTE]
how mcuh room between the rad and the first obstruction block side. if you have enough room then you can build a custome shroud to compansate for the air flow from the rad to below and over. the local tin basher could probably build you one for cheap...
glad to hear the truck is running well.
got any pics of your trip?
safe trip
cheers
kiwiwonder said:I wil be in guatamala in about a week and then heading down through central america to south america look fowart to seeing the cruisers there. I plan on puting in another thermostat just in case I got a bunk one from toyota. Other than the problem of getting a little hot it is great having a cruiser down here. seems like the diesel is better in mexico than the US has sulfer in it I think.
Radd Cruisers said:Little off topic, I have had 4 customers who have traveled through Central America in the last year and two more into Mexico.
Unique buntch of guys, not many would venture that far.
One of my customers just go back and had some great stories.
His vacume pump went out on him, a small maching shop turnned down the shaft, sleeved it then put in a small keyway. Took forever and was very finiky work, but its still working a couple thousand miles later. They even had to rebuild the viens out of plastic as the originals were toast.
iron_giant said:Don't worry Dave, I'll get you that calender next week.
