- Location
- United States
All of the work listed below has been completed within the past 4k miles by Randy at RT Customs. Has 33x12.50 BFG MTs on black steelies with around 1000ish miles on them(have discount tire receipt to prove). OME shocks/stablizer, Safari springs, MAF 4+shackles, extended braided steel brake lines. The 2F has been de-smogged since this no longer has to pass emissions(in TX). Has an ARB front bumper, custom sliders, custom rear bumper with tire carrier(new full size spare). No tears in the seats. This is a very very solid truck with a rust free frame. It has a rear cargo drawer as well. This truck isn't a show queen, but is as solid as they come. The only main issue is the faded paint with some surface rust and slight rock rash. I would be willing to trade for a comprable FJ40 + cash depending on the condition. Please e-mail or PM if you are interested. I'm located in Austin, TX
cabokpez@yahoo.com
Full tune up plugs wires cap rotor PCV fuel filter,
Valve adjustment,
Brakes front and rear with turn,
Exhaust manifold gasket and flange gaskets,
Clutch set,
Rear main seal,
Oil pan and gasket,
Transfer case rebuild,
Transmission seals,
Side rocker cover gasket,
Serviced axles,
Rebuild knuckles,
Balanced drive lines,
Pressure tested radiator,
Clutch slave cylinder and reservoir,
Master cylilnder,
New tie rod ends,
Replaced front output shaft seal
Replaced front pinion seal
cabokpez@yahoo.com
Valve adjustment,
Clutch set,
Rear main seal,
Oil pan and gasket,
Transmission seals,
Serviced axles,
Rebuild knuckles,
Master cylilnder,
New tie rod ends,
