Looks like we are getting to a laugh intermission in this thread.![]()
I tried...
oh my god, you designed a tow bar?!? WOW.
was the one from princess auto not good enough for him? gee, must take some real brain power to design one. hitch, 2 bars and a couple mounts... braggin rights for sure.
interesting blanket statement on RWD cars and trucks.
so... a 1970 dodge 1/2 ton share the same tranny, brakes and gearing as the old 70 dodge coronet but not the same in your books...got yah. i can see your age beginning to show.
.I have 2 bj40's and on the papers it says the car weighs 1560kg.
Max load load (car included) 2300kg meaning aprox 640kg loading in the car.
And max load pulling (also car included) 6300kg
This stands also on the ID plate of the car.
This is in Belgium
dont over load i flattend out my old springs(went from saggin to flat and fawked) by loading the bj60(N/A at this time) with too much lumber (3500lbs approx) the truck woulndt go over 90km/hr in 4th but the truck had no problem on hills slowed to 60-70km/hr these trucks haul ass but ill never overload my truck again
Go on, give the 40 series owners another kick in the ribs.
mind you the F 150 isn't a truck (according to your post above) so then it is a glorified 2WD car (which you do not accept as having any tow ability either).
I think what he meant wasn't that trucks are cars in other countries, but that in many countries the word "truck" only applies to large commercial goods transport trucks. An F150 might be called a "pickup" but if you say truck people think of something with 18 wheels. There is a differentiation which although confusing, is relevant to this argument because people are comparing "cars and trucks" and as this is an international forum, people are getting confused.
Lets see we got bait, quite a few hooks and lots of line. I got it, this must be the diesel fishing thread?![]()
BTW, I got a nice hitch custom designed and built here for under $300 (wiring included). Said it would tow 7500 lbs but said that 5500 lbs would be comfortable. Not sure if he was an engineer or a mechanic. Sure did handle the mig nicely. He must have been a welder....
...the new 70 series with a longer wheel base, stronger frame, disc brakes, 4.30 gearing has a LOWER tow rating than the old 40 series ...
found the answer jeep/4X4 or chassis model
i will correct my post
now, lets take this discussion one step further.
BJ42 ...................................................2008 70 series
90" wheel base ....................................117" wheel base
92 hp ..................................................151 hp (2wd) to 300 hp (4WD)
drum brakes........................................ 4 wheel disc
leaf spring........................................... leaf spring
4000kg tow rating................................ 3500kg tow rating
HOLD ON,DID I READ THIS RIGHT?!?!
the new 70 series with a longer wheel base, stronger frame, disc brakes, 4.30 gearing has a LOWER tow rating than the old 40 series with a shorter wheel base, 'C' channel frame, 4.11 diffs and drum brakes?!?!
some engineer must of screwed up on this one...
http://www.toyota.com.au/TWR/content/static/35224.pdf
No you still don't get it.
Here's a simple tutorial using the toyota family.
Car = Camry, Corolla etc.
Offroad passenger vehicle (SUV to the yanks) = rav4, highlander, 80/100/200 series landcruisers etc.
Pickup/Utility = hilux, landcruiser 70 cab/chassis etc regardless of deck fitted.
Van = toyota hiace etc.
Light Truck = Toyota Dyna etc
Heavy Truck = Hino 700 series etc.
As for towing with any of them, the only thing which legally matters is the rated towing and load capacity. Manufacturers' engineers tend to go on the high side. And they are probably pushed to do so by their bosses who want to use the selling point of higher towing capacity. So what you are allowed to pull and what is comfortable to pull is often not close to being the same.
Classification don't mean much to me. Here the insurance corporation has the classification of car, wagon and truck. Technically for them an 80 or a Ford expedition is the same as a Jetta wagon. The ministry of transport has just car and truck (which is based on GVW). All truck plates are commercial plates whether or not they are for commecial or pesonal use. There is a limit which then requeire you to stop at every scale. As for towing with any of them, the only thing which legally matters is the rated towing and load capacity. Manufacturers' engineers tend to go on the high side. And they are probably pushed to do so by their bosses who want to use the selling point of higher towing capacity. So what you are allowed to pull and what is comfortable to pull is often not close to being the same.
They are the same to me.![]()
