Well its been a while since I updated my thread, I'm not as good at updating as I thought I would be. For the most part I've been very happy with my setup, though I have thrown a few tweaks in here and there.
Since my last update I've gone up to 35's, added longer shackles, build a longer bed drawer and have been running my 4x4 labs rear bumper.
I upgraded to 35's after re-gearing to 529. I'm very happy with the combination. Before, with 33's and 456, I could barely climb hills in 3rd gear, now I can get up most hills in 3rd at about 3200rpm doing 60mph-ish with my highway speed around 65mph in 4th at 2600rpm. I'm getting about 14mpg.
I just recently added longer shackles because I was rubbing when turning under compression and I wanted more clearance for snow chains. I used the boomerang shackles from Sky's up front and 6" shackles from AllPro in the rear. The combination leveled my ride out and no more rubbing. The shackles did tilt my axles a bit so I added a 2* shim up front and changed my rear shims from 5* to 2*. That put my caster back to normal up front and fixed my driveline angles.
The only reoccurring problem I have had is my fuel pump wiggles out of its submersible fuel line causing a fuel pressure loss. The washboard roads of eureka and fish lake take it's toll. I ordered some submersible fuel line to lengthen the connection and reduce the strain on the little piece.
As it sits now;
Flex shot before shackles;
Snow wheeling;
Dropping the fuel tank;
And the problem;
