- Thread starter
- #61
ok I got it mocked up and so far so good. I originally planned on a bit more shackle angle but I used the pirate figure of 11" forward on front mount is correct therefore I subtracted the 11" from the 17.25 that I moved mine forward and landed on relocating the rear mount 6.25" forward. I think it will be about right once I get the bed made, spare tire in there, tool box, chains, etc.
I used a piece of pipe to keep the hangers in-line.
Here is a pic of the one side
I plan to put a rubber bump stop in there between the chevy shackle and the frame, and also a criss crossed limiting strap from the center of the pumpkin up to each side of the frame or make a little anti-cam set up on the shackle combo. I also plan to construct something to keep the chevy shackle from walking side to side while at rest.
to try and bevel like crazy, and weld two spline sections together (using a cut out window in one of my female splined sections as a weld window) as well as two female spline sections and lets face it IT DIDNT WORK!! I couldnt keep it cool enough to not warp a tiny bit making it TIGHT! Or if I did i didnt get enough heat to ever have it survive. At this point I have made the cuts and picked up some square tube and if it would ever stop storming for a second I could get home from work and whip it up!
SO.... I am contimplating just buying the sbc adapter for the 4 cylinder tranny and sacrificing the extra strength of the v6 tranny. Any thoughts anyone? The more and more this adapter word pops up the more and more I ask myself if I should have went with a sm465 and 205 and said screw the extra weight???????? I wanted the low first gear but didnt really want the large jump up to second
