Wanted 1980-83 FJ40 OEM Exhaust Heat Shields any condition
WIndermere
I am looking for the USA spec 1980-1983 exhaust heat shields for the exhaust system. I will buy either ones that are good enough to use or ones that are rusty that I can use as templates. Thanks
The ones that attach to the manifold?
Mark ,
These are UFGators heat shield's & related hanger / Bracket needs highlighted In Orange
I would say SW20's ride under your care right now would be a exact reference match
Thanks Matt. I think I've had a couple of those over the years and tossed them because of bulk. Then again, they could be packed behind a pile of 30 front bibs I haven't moved in this century!
Your Welcome Mark ,
Im Giving UFGators a hand trying to locate / source the above ,
- Our Plan B is someone out there has some Bang'd Up or Rusted ones Behind 30+ Front Bibs pressed up on the wall I can use
as a Pattern / Template to Fabricate New ones ...
if U find something above on the wish-list let us know
Thanks
Pretty sure I have both (58368, 58159 & maybe 17506... but they aren't for sale; can I take pictures & get you measurements? If you're fabricating something, the OEM part has a silver sort of coating to them. Looks sort of like the coating of an aluminized exhaust.
Now that I'm thinking about it some more, I still have the entire exhaust from the coupler at the manifold to the tail pipe (w/cat converter); In storage @my parents' so no telling when I'll be back that way to check.
that would certainly be helpful! I would appreciate it if not too much trouble.
So, I think I have most of the brackets and heat shields you are looking for. All except #17420, which is the one that clamps on the rear exhaust pipe. I'm not confident I have the rear body heat shield.
They are all in very good to excellent shape. There is no rust, they are just dirty. When I did my restoration 16 years ago, I sand blasted and painted the bracket, then took them off a few years later when I rerouted my exhaust.
I need to dig around for the other rubber donuts and the rear body shield (I'm not 100% I have this one, but I think I do).
$100 plus the ride for what's pictured from 20111.
2013-01-19-16-06-33-mobile-jpg.718762
