But I do believe the ‘79 and later got beefier pins, not sure about shackles.
All true but slightly less underbody clearance on ‘79 and later due to fuel tank and 3.73 gears vs ‘78’s 4.11 which I see as more desireable off road. On road the ‘79 and later was probably a slight improvement. But I didn’t buy mine for pavement.
Yes that is a good point, easier to upgrade the ‘79. I heard that back in the day guys were putting ‘78 axles on their newer trucks. I am planning on checking out either the campsite for Casner or FR300 this weekend. Weather is SO nice right nowSuspension upgraded started 8/80 along with the split transfer case and hand brake moved to the rear axle. 79 the metal got a lighter. Do not think this was solely for gas mileage but changes in how they were able to produce the 40 series. Same as the 72 which was lighter metal than 71. My real point was updating to newer superior parts is easier 1/79+.
Adding 4.11:1 diffs to 79+ would be much easier than adding a 22 1/2 gallon fuel tank to a 73-78. Also adding a H41 or H55F makes up for the higher diff gears. As for ground clearance from the factory that goes to the 79. The exhaust pipe mounted way below the skid plate on a 78 is much lower than the fuel tank on the 79. The exhaust running below the frame on the 79/80 bad but still better clearance than the 78. Working on a solution for that. Again like I state the 79+ is easier to add upgrades using later 4X series parts is why I prefer the 79+.
No problem at all. I just really want the jump seats instead of forward facing aftermarket. I don’t mind the gray.@danmc00 , just so you know, the jump seats I have are late (12/79) and hence are gray, with the fold-down legs. Still haven't had time to look for them yet; hopefully this weekend.
Any ideas on the top?
