1977 turn signal indicator help
dyersburg, tn
recently my turn signal indicators stop working intermittently. i've checked all the grounds i know to check. the hazard relay is working; however, the indicator lights don't work for that either. a couple of possible related items- when this occurs, the next time i try to start the vehicle the battery acts as if its dead. attached jumper cables and it immediately fires up. no charge time need. also, my temperature gauge was no showing a reading when this would be occurring with the turn indicators; however, now it does and it's just the indicators and battery/starting issue.
thought?
You should identify exactly what grounds "you know to check" so someone could identify the grounds you don't know to check.
