1977 Toyota Landcruiser FJ40 For Sale Delaware
Photo Album link (ask if you need other shots)
77 FJ40
Solid frame and body –all rust surface only( except along center bottom of windshield )see pictures. Purchased 2012. Garaged until last January.
Exhaust - When I purchased it, it ran but failed inspection due to a manifold exhaust leak and also it had no catalytic converter. Being from California it had a thermoreactor manifold (which I still have and comes with the purchase). I switched it with a standard intake/exhaust manifold with new gasket. And converted to Trollhole carb to avoid vacuum system issues. I have numerous exhaust parts including two mufflers but exhaust needs completion. Also included is the downpipe and flange(that’s a $75 dollar part by itself)
Engine- very good condition -I researched vin online and found and contacted a previous owner who was President of a California chapter of Landcruiser club. He informed me that the engine had been rebuilt while he owned it which I estimate was at most maybe 5k miles ago.
Body/Frame – very solid with no rust through -PO mentioned rust under rear top lip but I have not had the top off and see no signs of further expansion – there is bubbling on windshield frame corner (see pics) all other rust is surface only and very minimal –Frame is solid
Tires – New ( maybe 200 miles on them)
Other noted issues – signs of Birf leak
Currently not running – IH8MUD Forum member Shark56 can attest to fact that this landcruiser does run as he helped in the past with some repairs.
Comes with lots old/new parts including
Steering assembly, center console, new hubcaps(current wheel do not have clips), two jump seats(one welded restored, one very rusted), rear aftermarket bench seat, original Asian carb, themoreactor manifold (unrepaired), full set of manuals, canvas bimini top and rollcage divider, and whatever else I have accumulated over the years.
In addition this includes over $8500 worth of parts and labor by PO. All receipts included
Warn Winch
So for $15000 you get a solid no rot Landcruiser with a rebuilt engine, rebuilt brake system, front end, and lots of the little stuff with extras.
If you put a little time/effort, mimimal cost depending on you skills and a decent paint job you’d have a really nice example of a TLC.
See my album for more pics. If you require other angles/shots please let me know
exhaust parts 163.26
manuals 140
brake hose kit 96.65
pedal pads 26.35
shift boot and plate 59.4
dome light assembly 43.95
license plate dome cover 57.9
brake pad and calipers 381.99
tailshaft seal replace 1027
Master cylinder 84.5
4 brake shoes 44.5
1 wheel cylinder kit 135.95
2 monroe shocks front 74.3
2 monroe shocks rear 75.2
4 wrangler duratrac tires 917.67
2 front seat recover 390
weatherstrip 100
wiper switch 57.81
dash cluster bulb 14.91
plug/coil wire set 37.68
hood bracket windshied supports 46.29
Mat set 2 59.95
cargo mat 79.95
seal weatherstrip emblem 36.5
shift knob assembly 29.95
hooks latches hood to windshield 2 18.95
rear view mirror and arm 19.5
turn signal lens front 2 47.5
ambulance door weatherstrip 2 79.5
hood pad kit 18.95
Trollhole carb 200
tail light gasket 9.95
Toyota dealership brake job includes replace pads machine rotors, repack wheel bearings replace seals, new steering damper
Toyota Dealership front end job includes tie rod clamps, coupling assy, tie rod end sub-assy, reman gear box, tie rod ends hub bolt, nut
Toyota Dealership Coolant system job includes water pump, thermostat 3949.29
TOTAL RECEIPTS = $8525.3
77 FJ40
Warn Winch
manuals 140
pedal pads 26.35
4 brake shoes 44.5
weatherstrip 100
wiper switch 57.81
Mat set 2 59.95
cargo mat 79.95
hood pad kit 18.95
Trollhole carb 200
