Parting Out 1977 FJ40 parts
in need of the metal radd protective screen w/ TOYOTA emblem, choke cable with hardware that fasten it to the carb linkage. and one of the dash brackets that hold the windshield up. please.
WHATS LEFT
Intake , exhaust manifolds, steering column, exhaust system, radiator, dist, caRb, air cleaner, cal spec air cleaner hose, speedo, seat belts,
center console, rear heater , heater hoses, heater valve, 10x15 aluminum wheels, e brake cable, e brake assembly and most of the small parts
Can you send pics please of:
Heater, hoses and valve
Seat belts
Do you still have steering box?
Thanks
J
WHATS LEFT
How much and can you post photos of the air cleaner assembly? Does it include the intake horn?
Can you post a pix of the end that goes into the manifold of this: exhaust system down pipe
Mine is corroded away, and I need a clean/intact manifold flange and pipe-end. Thanks! - Steve
Do you have a good radio? and passenger door panel?
Hazard switch w/ knob (or other on/off switch) matching what is on a 1978 FJ40 w/ ship to 60614? I'm adding a switched accessory to existing hole in dash and I want a matching switch/knob. Thanks.
Do you have the interior door panels?
